Question about D-Link Computers & Internet
Windows installer vista
I have a MSI 11g wireless micro router, but for some reason it wont let my laptop, or my tablet connect to the internet, What should I do?
  • D-Link Master
  • 16,404 Answers
Reset the router and on some models you can do this with a pin hole in the back or bottom. Also to change the settings on the router, you have to be connected by wire, you cannot use wireless.
Posted on Feb 09, 2014
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
watz up
  • 6 Answers
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Posted on Sep 11, 2008
SOURCE: 3Com OfficeConnect Wireless 11G password
Press reset button on the rear of the unit for 5 secconds, then by connecting your moden in to yor laptop go to the following web page: http://www.3com.com/products/en_US/detail.jsp?tab=support&sku=3CRWE454G72&pathtype=purchase and there you will find the software and manual for your AP (access point) the software will let you setup the device from scratch. the default password is admin. hope this helps.
Posted on May 24, 2009
Geekman
  • 32281 Answers
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Posted on Sep 29, 2009
govinda123
  • 2263 Answers
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Posted on Feb 01, 2010
THERS IS NO INTERNET SERVICE ON MY TABLET
What is the tablet? Are you able to connect to the wireless gateway via your pc/laptop?
Check in the tablets settings and make sure "Data/Cell" services are OFF and that the "Wifi" or wifi adapter is turned ON.
Let me know how you make out.
Jan 26, 2014 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...
www.opensuse.org/
Dec 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
I have 2 laptops. One with windows xp that is connected wirelessly to the router. The other runs windows vista and its connected wirelessly to the network but it says unidentified network and wont connect...
check your ruter .. log to your rutter end see what is in ssdi.. what nameing? see securtiy also... check your wirreles adapter , maybe new driver for vista needs o be install
Feb 25, 2011 | Belkin Basic Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Hardwired pc cannot recognize network (local access only)
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
Note: Name (11N SSID) is for wireless N computers running at 5GHz and the Name (11G SSID) is for wireless G computers running 2.4GHz. Kindly make sure that (11N SSID) and (11G SSID) names are different.
c. Set the mode to Up to 270Mbps at 5GHz & 54Mbps at 2.4GHz.
d. Set the 11N Channel to 48 / 5.240GHz and 11G channel to 1 / 2.412GHz.
e. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
6. Connect wireless computer to the router.
Note: If your wireless computer supports 5GHz and 2.4GHz frequency you will see two wireless networks which are 11N and 11G SSID. However, if your wireless computer only support 2.4GHz frequency you will only see one wireless network which is 11G SSID.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet with the ideal speed you have from your ISP.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Who is your internet service provider? Is it Cable or DSL connection?
2. How many wired and wireless computers are connected to the router?
May 16, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Have bought Belkin 802-11g router for our laptop. Computer uses MS vista. Disc that came with router is not compatible with vista. Am not technical with computers at the best of times. So... how the hell...
any router or disc should be compatible with any version of windows, if you mean the wireless reciever/dongle, the go here for drivers
http://catalog.belkin.com/IWCatSectionView.process?Section_Id=204037
If you do mean the router, then connect to your laptop using a lan cable supplied with the router, then you can get into the router by opening internet explorer, the type in the web address, either 192.168.2.1, or 192.168.0.1, i forget which it is.
This will bring up the password and user name, which is in the manual and then enter your isp's dial up details
Aug 17, 2008 | Belkin Computers & Internet
Router Netcomm NB-5540 11g type 54Mbps
Was the router installed on your computer? Try calling the manufacturer or whom you recieved the router from. Don't see a reason why the router shouldn't work.
Jan 17, 2008 | EnGenius EUB-362 (EUB362 EXT) Wireless...
MSI rg54g3 ieee802.11g vista driver
Generally you do not install a router onto a PC you connect to a router with a wire using a network adapter or wirelessly with a wireless adapter. Can you any of the following you have identify you make and model of PC, make and model of add-on adapter card? Then I may be able to assist you in determining if a driver exists for the device attached to your computer intended to communicate with the identified router.
Thanks
Dec 09, 2007 | MSI Wireless-G RG54G3 Router
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
