Question about Lands Phones
How to turn off diversion? - Lands Phones
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
How did you divert calls in the first place? If you did it with *72, try *73 to cancel. Otherwise, contact your telephone service provider for their instructions.
Posted on Feb 09, 2014
1995 Yamaha XJ 900 Diversion fork oil capacity
Hi, Sharon for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XJ 900 Diversion 97 03
Motorcycle Fork Oil Change Part 1
Yamaha 95 XJ900S Service Manual
OEM parts for Yamaha
Yamaha diversion 900 XJ900S Owner Manual
Jun 02, 2017 | 1995 Yamaha XJ 600 Diversion S-N
Phone diversion wont turn off?
Can't you just contact your systems admin? :)
Are you sure you turned off the call forwarding?
http://service.us.panasonic.com/OPERMANPDF/KXTVA50.pdf
May 21, 2015 | Panasonic KX-T7636W Corded Phone
Where is indicator fuses on xj diversion 900s 1988
Hi, Ian for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1988 xj diversion 900s turn signal fuse location Google Search
Wiring Diagram Schematic for XJ600 1989 needed
http://inetdni.home.xs4all.nl/motor/manualxj900s.pdf
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Mar 29, 2015 | Yamaha Motorcycles
How do I set up a call divert
If this is an exchange line, and the facility is enabled, in Europe and the UK, you would key *21*01234567891# where 01234567891 is the number to which you want to divert the call.
Wait for a voice announcement, and the exchange will tell you that you have turned diversion on. You will frequently hear a different dial tone as a result.
To remove diversion, key in #21# and the dial tone will revert to normal. The exchange will also advise you of the diversion's cancellation.
Feb 11, 2015 | Lands Phones
2010 xjs 600 indicators stopped working
Hi, Anonymous before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
XJ600 Diversion indicators not working
Headlight Indicators Not working
Yamaha 2009 Diversion XJ6S Service Manual
Yamaha Diversion XJ600N Owner Manual
Sep 23, 2013 | 2010 Yamaha XJ6 Diversion
Starter relay location on 600 diversion
Hi, Grahammackie for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Need help with starter relay XJRider com
Starter relay location on 600 diversion Google Search
Yamaha XJ600S 1992 Service Manual
May 23, 2012 | 1992 Yamaha XJ 600 Diversion S
1992 Yamaha XJ 600 Diversion S lost the only ignition key
Hi, Brian for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Keys XJRider com
26results for yamaha xj600 key
Yamaha DIVERSION XJ6F Owner Manual
Dec 20, 2011 | 1992 Yamaha XJ 600 Diversion S
How much fork oil to put in XJ 600 Diversion 1998?
Hi, S_sloman for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XJ600 Diversion Specs and Info WhiteDogBikes Blog
XJ600 Seca II Factory Specifications Specs XJRider com
May 31, 2010 | 1998 Yamaha XJ 600 Diversion S-N
Takin off the dash lights on a 1995 yamaha xj600
Hi, Ctw2k4 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XJ 600 Diversion 1995
Yamaha Diversion
Mar 01, 2010 | 1995 Yamaha XJ 600 Diversion S-N
Yamaha XJ600 diversion starter motor problem
sound like your starter gear might be missing a tooth or some other king of damage, this shouldnt be a costly repair, but I wouldnt ride too much as it is, if there is a chunk of the starter gear in the transmission, this could cause much damage and be very costly
Aug 12, 2009 | 1995 Yamaha XJ 600 Diversion S-N
Lands Phones Logo
66 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
