Question about Scubapro Soft Travel Backplate
Scubapro Soft Travel Backplate - Scubapro Soft Travel Backplate
Problem E 6 comes up on my uwatec smart com
I have a smartcom very nice dive computer this issue can ONLY be repaired by scubapro themselves the smartcom is obsolete they will give you trade dollars toward a galleo or luna which are better dive computers
Feb 05, 2013 | Scubapro UWATEC Smart Com Console Dive...
Schematics for a scubapro mk17 regulator
these are controlled by scubapro due to they need specail testing equipment to repair regulators E..G now IP pressure is 135 psi and there is no adjusting screw shims and springs then the cracking effort test to see if you have pressure flutter or creep. these can not be seen with out testing equipment.
Mar 18, 2012 | Scubapro Scuba Diving & Snorkeling
Service
You will need to contact your nearest Scubapro authorised dealer. You can look up your nearest dealer from the main scubapro website. Most Scuba shops that undestake servicing will be able to sort this for you as scubapro is a worldwide brand.
Oct 03, 2010 | Scubapro MK2 Plus/R295 Regulator
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) +...
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Jan 21, 2010 | Scubapro MK11/R395 Regulator SCUBA...
I need to strip down my s555 regulator to find
Check here:
http://www.frogkick.dk/manuals/scubapro/Manuals/2.%20Stage/
May not have exactly your model, but something very very similar. Also, keep in mind, the second stage will free-flow as an "overpressure safety" if the first stage is malfunctioning. Check your intermediate pressure (should be ~150). If you can't do this, try your second stage on another first stage (any brand), and try another second stage on your first.
If it is for sure your second stage, check for proper adjustment of demand lever, bent/damaged demand lever or diaphragm plate, or damaged valve seat.
Jan 18, 2010 | Scubapro Service Diagrams Scuba Regulator...
Anyone know where I can get a Scubapro repair guide for the R295?
check here: http://www.frogkick.dk/manuals/scubapro/Manuals/
Jan 16, 2010 | Scubapro MK2 Plus/R295 Regulator
My problem is i don't have anymore teeth in my mouth i can not bite the regulator if i dive, my regulator will detached to my mouth and i can not proceed with my work as underwater assistment.
They sell aftermarket mouth pieces that you warm in water once soft and pliable you bite down it takes shape to your bite plate which is further back in your mouth and can not be pulled out .
Dec 04, 2009 | Scubapro MK25/G250 Hp Regulator
How to use safe second with a Scubapro full face mask
Yu only need the octopus adapter kit to put on an octo and you can swap out should your primary reg **** out.
Feb 18, 2009 | Scubapro Full Face Mask, All
Scubapro Soft Travel Backplate Logo
63 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
