Question about Uniden BC340CRS Base Scanner
Cannot get scanner programed
Got new scanner but cannot figure out how to get it programed. Had 3 other people try but couldn't figure it out I need help from beginning to end
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
Most radio scanners these days have software that you can program from your PC etc, You will also need a cable, if not supplied. Check at the Uniden website. However you should be able to program it manually. Again the instructions that came with it? should tell you how.
Normally a scanner can be programed to scan between two frequencies ie 144 to 146 for the 2mtr amateur band etc
or you can program channels.
Posted on Feb 09, 2014
Motorola LI4278 Scanner 3of9 prefix ~ tilda
there's a program called 123scan2 where you can configure a prefix and outputs a program barcode
Feb 18, 2014 | Zebra LI4278 Barcode Scanner
Radio shack iscan trunking scanner, pro-107
I no longer provide support for any scanners. As a Police Dispatcher I was working when two police officers were ambushed and killed because a person listening to a scanner told the suspects the police were coming. They should be outlawed.
Dec 19, 2011 | Radio Shack Radio Communications
Hi, I want to install both fujitsu fi 5750c and 5530C2 Scanners in same PC. OS is win XP. I tried through setup, but when one is installed, second one's setup says already having Scanner Utility...
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 27, 2011 | Fujitsu fi-5750C Flatbed Scanner
Grasslin FM1D20A 120 PLEASE....I need a full programming manual on this unit. It was installed in a brand new Engineered Air rooftop air cycling unit last fall and it is a nightmare to program. It...
FM1D single-channel timer is difficult to program.
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM40AVE
http://waterheatertimer.org/pdf/fmd-20-setpoint-programming-guide.pdf
Timer flowchart starts page 3.
First step is to select format and then set current time.
Format is asking if you want 24hour or 12 hour format:
12 hour is am and pm
24 hour is military time where 11pm at night is hour 23.
Current time is simply the time right now.
Next step is to set program 1 thru 20 (P01 P02 thru P20)
Start by pushing +/- until desired program displays
Each program is set for either ON or OFF.
There are 20 memories available: 10 ON and 10 OFF.
Not necessary to use all 20 memories.
You need to set at least 1 ON time and 1 OFF time.
Make chart of on-off schedule to avoid conflicts in programming: For example ON at 7am Monday and OFF at 9am all-days-of-week will cause timer not to function as expected.
Each ON time is set for hour, minute and day.
Each OFF time is set for hour, minute and day
Press menu to terminate programming.
Add a comment for specific help with this timer.
Jul 26, 2011 | Hardware & Accessories
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
Having major issues with programming my bearcat bc60xlt-1
You'll need to program the radio frequencies into your scanner before it will scan . For a list of frequencies in Anoka County CLICK HERE .
For specific programing instructions for your UNIDEN refer to your owner's manual. They will give you a step by step instruction on how to program the frequencies into your scanner memory (If you need a manual, CLICK HERE
...be sure to select the scanner option on their pull-down menu.
THEN when you have the radio frequencies stored into your scanner, you'll be able to press scan and away you go.
Be sure to adjust the squelch just high enough to eliminate the static...turn the squelch counterclockwise until you hear loud static, then turn Clockwise just enough to silence static...
Let us know if you still have trouble.
Jul 20, 2009 | Uniden BC60XLT-1 Handheld Scanner
I bought the scanner usb cable and cant figure out how to get new codes to program my scanner.
You will also need a software package to program your scanner. Unfortunately the cable does not come with the software. Try going to www.starrsoft.com and download a program called Win97. It is free for 30 days and makes programming a breeze and it can also interface with radioreference.com (if you are a paying subscriber to the radioreference.com site) to download automatically.If you don't mind doing a little typing, you can view the info on the site for free and enter it into the program.
Apr 26, 2009 | Radio Shack Pro-97 Handheld Scanner
Program a new number
Here are all the scanner manuals. unfortunately yours is not there. I would check the model # again with the ones on the list. Or look at one the is close to yours to figure it out. sorry I can not help anymore
http://www.uniden.com/index/manuals_results.cfm?cat=3
Good Luck.
Dec 29, 2008 | Uniden BC72XLT Handheld Scanner
I need a driver for an acer 6678-owe flatbed scanner for windows vista
I searched pretty hard and couldn't find any Vista drivers. I assume that scanner is relatively old. You can try this, but I don't know if your scanner has software:
Go to Start, then Control Panel, Programs, and under Program Features you'll see something that says "Use an older program with this version of Windows." Try messing with that and see if you can figure anything out. But I'm pretty sure there are no Vista drivers for that scanner.
May 24, 2008 | Computers & Internet
Uniden BC340CRS Base Scanner Logo
141 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
