40" flatscreen tv looses its color after 15 minutes
Looses it color after 15 minutes! What would cause problem and the name of part
  • 74 Answers
Try to check or ensure that there is no magnet or a speaker with a strong magnet near the tv
Posted on Feb 13, 2014
4 Suggested Answers
  • 105 Answers
SOURCE: No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
Posted on May 22, 2009
  • 244 Answers
SOURCE: Problem w/brand new 42" Insignia Flatscreen TV
if it's still under warranty- get it replaced!! while you can!
shouldn't be doing this! at least until warranty runs out- you know how that goes!!
if it was quite expensive- might try for extended warranty- if not too outrageous!
good luck!
Posted on Oct 17, 2009
joeguest2
  • 2080 Answers
SOURCE: i have a samsung flatscreen
With the lights in the room turned off, does your TV screen still glow when it is turned on even though there is no picture signal there?
Is the sound still working or does that shut off too?
Does the small power indicator light change color when you turn the set on and when it shuts off by itself?
If your screen stays completely black, then m
ost often this symptom is a result of a failing POWER SUPPLY but a faulty MAIN BOARD or INVERTER BOARD can certainly cause very similar symptoms. Unfortunately, without a donor TV to swap parts with or a dedicated test rig, it can be very difficult to differentiate between these problems.
One quick way to test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one, since this is the most often the source of the trouble.
You can usually find replacement supply circuit boards online by searching for your TV's model number.
Here is a link to the SHOPJIMMY.COM parts supplier website which lists all the replacement circuit boards available for your model of TV along with their prices:
http://www.shopjimmy.com/samsung-ln46b610a5fxza
And here is the direct link to the POWER SUPPLY CIRCUIT BOARD for your set:
http://www.shopjimmy.com/samsung-bn44-00265b-power-supply.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed if necessary, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your circuit boards and confirm that they exactly match the ones provided in the online listing. Also make sure that any part you order is labelled "TESTED WORKING" in the condition description. Any part with a condition description of "AS IS" is probably faulty itself as well.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit boards. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
Here is a link to another Expert's solution to a similar problem which includes links to his excellent and informative set of LCD TV / MONITOR TROUBLESHOOTING GUIDES:
http://www.fixya.com/support/t10008425-when_turn_tv_picture_flicks_off
These guides will give you some idea of the various problems with LCD monitors and the associated repair procedures.
If you choose to rate BUDMRTN's troubleshooting tips by clicking on the YES THIS WAS HELPFUL icon on his solution page at the above link, then I thank you very much for your time and consideration.
Please comment back here to this page if you have any details to add, have any questions, have difficulty with the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
Posted on Sep 05, 2011
My 1995 ford explorer looses power after 40 minutes of driving. I turn off wait for 10 to 15 minutes then resumes again.
Bummer deal! Sounds like the fuel filter is clogged. My motorcycle did the same thing and a new filter and a special kind of additive treatment restored its like new power - though 15 years old. The product from Mega Power is listed below and can be ordered on line. Its made for cars - and a motorcycle works exactly like any car does. Rarely, a fuel pump going dead will overheat and stop. Then restart. You can change the filter. A mechanic can check out the gas pump - Hope this helps. DIY fuel injector cleaners fast acting Ends several tune up problems
Nov 05, 2014 | 1995 Ford Explorer
Screen inverts colors
check if the cables are loose... sometimes a loose cable can cause this.
other than that, something could be malfunctioning inside, but that will be a lower probability.
Apr 23, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
good luck!
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
1984 GM 7oo R4 automatic trans. looses power while setting
MAKE SURE TRANSMISSION FLUID LEVEL IS CORRECT. BUT THE TRANSMISSION OIL PUMP IS TOO WEAK.IT NOT BUILDING UP ENOUGH PRESSURE FOR THE FORWARD CLUTCH PISTON TO APPLY.ALSO YOUR FORWARD CLUTCH PISTON SEALS.COULD BE LEAKING.WHEN ENGINE GET WARM AND THE TRANSMISSION FLUID GET WARM.IT CAUSES FORWARD PISTON SEALS.TO EXPAND ENOUGH TO BUILD UP PRESSURE SO THE FORWARD CLUTCH PLATES WILL WORK.LOOK LIKE YOU ARE GOING TO NEED A TRANSMISSION OVER HAUL.
Aug 30, 2009 | 1984 GMC S-15 Jimmy
Tv looses color
your tuner seems to be bad
Nov 27, 2008 | Televison & Video
No sound
Hi,I have samsung T.V. but nearly 2 OR 3 months we had a problem of no sound (It is an on and off trouble) .can you tell me about this?
Name-Om Prakash Pareek
Address-H-32 shastri nagar,jodhpur
phone -2641100
Jul 21, 2008 | Samsung LN-S4051D 40 in. LCD Television
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
