Question about Kenmore 665
Dishwasher f4e1 Tried unplugging dishwasher and waiting 1 hr and the code f4e1 will not disappear.
  • Anonymous Mar 12, 2014
    error code F4e1
  • Kenmore Master
  • 16,026 Answers
This is an error that means the controller is not talking to the motor. You need to check the connections on the motor
Posted on Feb 09, 2014
  • Alex Smith
    Alex Smith Feb 12, 2014
    All of the wires look tight on the motor and the pump. Any other ideas?
  • Brad Brown Feb 13, 2014
    That was the hopeful easy fix, the only answer now is to replace the motor controller.
My kenmore dishwasher not working code f4e1 came on
I checked the searspartsdirect.com website, and according to them, it is a 'motor communication issue.' In order to get more details, you have to create a login, and it was taking forever to complete that, so I gave up.
Try flipping the circuit breaker, leave it off for 1 minute, then turn it on again. Do you still get the error code?
Okay, I finally completed the sign-up process. Here is some more info from an actual repair technician:
The F4E1 is a code that signifies a WASH MOTOR
issue. Specifically, no Communication. This is usually caused by: A loose connection in Wash Motor Circuit, Motor Communication Circuit and/or an open wash motor. 1. Unplug dishwasher or disconnect power. 2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit with meter. Fix/replace an open connection/part. Motor fuse on control open. 1. Start Service Diagnostics Cycle using keypad and advance through the error code intervals to interval 19. ( shown on image below ) 2. Listen for 2 relay contact clicks at the start of interval 19 (to confirm both the pilot and motor relays are turning on.
NOTE : These relays provide power to the motor, but the motor does not start until it receives a start command later in the cycle). If hear only 1 or zero clicks and wash motor does not come on later in service cycle, and there were no loose wire communication wire connection when checked above, then unplug dishwasher or disconnect power and replace control.
Faulty wash motor. 1. Unplug dishwasher or disconnect power. 2. Use inspection mirror to inspect for water leakage and/or overheating on the wash motor. If evidence of overheating exists, replace wash motor. If evidence of moisture exists, check seals and hoses.f you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Jun 11, 2014 | Kenmore 665
My built in dishwasher ser no sm843049B-Model number GSD696ON1OSS will not reset. I mistakenly used the delay wash setting. It is set at 1 hr. I have used the start/reset button several times and the...
Try to do a hard reset by unpluging all the cords for 1hour and then plug it back.
Goodluck,
Please don't forget to rate the solution
Apr 11, 2008 | Dishwashers
Dishwasher code F4E1
The F4E1 is a code that signifies a WASH MOTOR issue. Specifically, no Communication. This is usually caused by:
2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit. Fix/replace an open connection/part. Motor fuse on control open.
Using keypad press "Heated Dry", "Normal Wash", Heated Dry", Normal Wash, and the "cancel button" to reset.
Start a cycle and listen for 2 relay contact clicks at the start of interval to confirm both the pilot and motor relays are turning on.
Apr 21, 2014 | Dishwashers
Error code F4E1 need reset
Turn off the power to the dishwasher for about 5 minutes before you power it up check that the water supply line is on. Also check for restricted drain area. Power it up and clear the power fail fault see if it works
Feb 24, 2014 | Kenmore 24" Built-In Dishwasher, Stainless...
CODE F4E1 will not go away
This error means that the controller cannot communicate with the motor. It is possible that something came loose when you replaced the clamp. Recheck all the connections .
Feb 09, 2014 | Kenmore 15322 / 15324 / 15329 Built-in...
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
Hi, my blaupunkt radio is displaying wait 1 hr, cant shift it. any solutions please.
WAIT 1 HR means wrong codes have been entered previously
To restore, leave SWITCHED ON ..UNDISTURBED for as long as it takes to automatically reset itself
In this case it should be 1 hour
Make sure you have the correct code
Feb 01, 2011 | Blaupunkt San Remo CD32 CD Player
Screen frozen with 1 hr remaining
unplug it for a few minutes, see it that resets it.
Mar 02, 2010 | GE Dishwashers
The machine seems locked on 1 hr..wont clear or
unplug or turn off power . turn back try to program . if no luck / look for code on digital display . if no code replace the touch panel .. it has a stuck touch pad. ,, mm
Dec 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Maytag Neptune MAH8700AWW Error Code Hr
this is joyce:
have you tried just unpluging the unit from the wall and waiting for 1 min and repluging it into the wall, this usually resets any codes. if not I will be happy to research this for you, infact I am doing it now while we speak, you try the simple method first. and let me know how that goes. my name is joyce
Jan 07, 2009 | Maytag MAH6500 Neptune Front Loading...
Kenmore 665 Logo
222 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
