Question about Breville BKC700XL Stainless Steel
Slow drip It starts off fast and goes to a slow drip or a stop in he middle of brewing.
Saeco odea does not brew coffee, all the water goes in the drip pan
Hello, the water in drip pan is clea water ot coffee water?(brown). Take a pucture inside machine with no brew unit inside.
Aug 27, 2017 | Saeco Coffee Makers & Espresso Machines
My Keurig will only drip water when brewing. I've descaled, changed the filter, machine is only year and a half old.
#1. Use the paper clip trick on both top and bottom punchers. The holes are in the side of the punchers. (lots of video in youtube) #2. Descale it again with vinegar and leave it for 15-24 hrs before brew rinsing, (instead of 4 hours as mentioned on the manual) #3 some said, turning it upside down and giving it a shake, #4. visibly check the screen on the the water reservoir tank entrance clean if there's any visible clog. #5 Still having a problem, then, for the last resort, before deciding on replacing the diaphragm pump, open the bottom metal part (5 screws), inspect for any visible drip of water (accumulation of white hard water stains, or discoloration on the metal) visualize where it's coming from. Mine is on 2 areas--from the diaphragm pump (where there's 3 black screws) and where the connection of the main pump to the reservoir. This is good news, it means nothing wrong with the pumps. it's just been leaking a little bit of water on the connection (must be air tight, any leak will decrease the pressure). The common sense FIX: depress the metal clamp and pull the plastic tube out, clean the inside and the connection and re-attach it back making sure the little leak will stop. same with the other one then, then replace the other smaller tube with a new tie wrap and make sure it's air tight. Basically you just check all the hose connections make sure it's air tight..
Jun 14, 2015 | Keurig B70 Coffee Maker
My coffeemaker will not stop dripping after the coffee is brewed
If this is a small brewer it's most likely that the brew valve is not closing fully after the batch. This is often a result of the plunger inside the valve having a worn seat. Without knowing the make and model it is not possible to give much more detail.
Dec 13, 2014 | Coffeemaker Coffee Makers & Espresso...
Mini keurig stops brewing and blows tops off k-cups
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Error message: 'brewunit is blocked' and i cannot get the brewunit out of the machine to look at it. it is stuck pretty hard. dont want to break it...any suggestions?
Hi
Your showing a Syncrony but this is for a Syncrony Compact. They are different.
Open the door. Remove the drip tray, dredge drawer. On the left side and towards the back of the brew group, there is a single screw in the brew group. If you can't get the dredge drawer out, just move it as far to the left as you can to get to the screw. Remove the screw. Grab the handle, squeeze and pull carefully, but firmly fast. Everything will come out (drip tray, dredge drawer, brew group and there might be water in the drip tray). The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and then to the center of the brew group. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group into the machine. First you must insert the dredge drawer back into the machine. Close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, pull out the dredge drawer, drip tray, then open the door and insert the brew group. Slide the drip tray,dredge drawer back in, close the door and test.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Breville BKC700XL Stainless Steel Logo
61 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
