Question about Thermador SEC302 Electric Double Oven
Broiler element doesn't work
Hi. The broiler element does not work on my Thermador SEC301BB/01. I have replaced teh element and reset teh main circuit breaker. The bake element works fine as does everything elase (timer, light, clock, fan, etc). Any suggestions? Thanks.
    Problem Solver:
  • 10 Answers
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Posted on Feb 09, 2014
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: bake element does not heat up but broiler does. Do
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 08, 2010
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Posted on May 23, 2010
rickead1
  • 1998 Answers
SOURCE: Thermador oven bake is not
first thing you want to do is turn off the gas the next thing would be to locate the ignitor in your oven now sometimes on thermador they are located below the lower kick panel and on other units they are located inside the oven below the heat plate when you do find the ignitor take a voltage meter or a multimeter and set it to continuity clip around one of the oven ignitor wires should be drawing 3-3,3 amps when you turn the oven on any less and you would need to replace the ignitor which in most cases is the problem you haveing seeing how it is not lighting and you are smelling gas if you have any further questions message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation thanks again
Rick
Posted on Dec 28, 2010
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Thermador SEC301BB broiler doesn't work
the broil element
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Thermador SC301TS Neither oven nor broiler will heat up
most likely the thermal safety was activated and needs to be reset if not, you have a bad relay board.
Mar 02, 2013 | Thermador Ovens
Bake element does not heat up but broiler does. Do
heatman101
Apr 06, 2010 | Thermador SMW272 Electric Double Oven
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
Thermador SEC302 Electric Double Oven Logo
279 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
