Question about Microsoft Office Outlook 2003 for PC
What is the defination for parellel lines - Microsoft Office Outlook 2003 for PC
    Scholar:
  • 67 Answers
I linked a wiki page below.
Basically what is meant by parallel lines is two lines on the same plane that would never cross no matter how long they were in either direction.
Parallel geometry
Posted on Jun 05, 2014
Hi I have a Sony Bravia 32i TV, When I switch it on I am getting sound but a series of thin (coloured ) parellel lines across the screen instead of a picture. Is there anything I can do to rectify it.?
This is caused by the failure of the T-Con board, you must replace it. You can get one from here
http://www.shopjimmy.com/tvs You will need the exact model number, found on the label at the back.
Apr 13, 2011 | Sony Televison & Video
I have a 2230 printer with a parellel cable but my computer doesn't have a parellel port only a USB is there a way to buy any kind of attachment for this.
Yes. you can find parallel to usb cable which cost around £5-10. Alternatively, is your printer have network port...you can use that also to connect it to your computer.
Mar 20, 2011 | Office Equipment & Supplies
How do i time a 250 sx 3 wheeler
NOTES:
The cam gear has 2 holes opposite from each other, some have slash marks.
Those marks will be parellel with the head once the timing chain is on.
Both intake and exhaust valve will be closed.
If the lobes on the cam are up, then your 180 degrees out and need to flip it over
Assuming the jug is on , and motor is on TDC, install the head, hold the cam with the cam gear attached tand place it in the head with the lobes down in its place, look at the marks on the cam gear and keep them parellel with the head, put the timing chain over the cam gear carefully.
once the chain is on, check that the motor didn't move and is still on TDC, and that when you lay the cam all the way down, the cam gear marks are parellel with the head.
If the marks are parellel and motor is on TDC, now you can put your rockers back on and adjust your valve clearance. .03 intake .05 exhaust
Install you exhaust, intake , carb, etc and fire it up.
Dec 09, 2010 | Honda NS 250 R Motorcycles
White parellel lines on the print taken
the print head from your cartridges are damaged or cloged with dryed ink.
Put the cartridges in warm distiled water for 30 min. and try to print again, if the problem is the same replace your cartridges.
Nov 18, 2010 | Canon PIXMA MP160 All-In-One Printer
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
How do I set the timing on a 1997 Dodge Neon with a single cam
While this is kinda of tricky but you should like your in it so hears what i know.
To set the timing your looking at two marks, these marks can be defined as a dot an arrow a hash,...you have 1 on the crankshaft gear and the camshaft gear.
Now there should also be a mark on the engine itself again a arrow a hash a dot some marking. so what you want to do is line up defined mark on the toothed wheel with the defined mark on the defined engine mark. this applies to both gears. they must line up. Here's where it gets tricky. You need to be on the compression stroke for cylinder #1. you can buy this at a local auto store. So put everything together....
When you remove the spark plug and put the compression tester in cylinder 1...set your camshaft on the defined marks lining them up then slowly turn your crankshaft, what you looking for is pressure to build in cylinder 1 if nothing develops, take the camshaft and rotate it on full rotation lining the marks again and turn the crankshaft looking for pressure. once you get it make sure you line up your marks and set the belt on good luck hope i helped
Dec 27, 2009 | 1997 Dodge Neon
I keep getting error for line 15
There's too much apostrophes in define('EMAIL_SUBJECT', ... Is this line 15?
Change it to define('EMAIL_SUBJECT', "Enquiry from 'MMSWEETS'");
Oct 17, 2009 | The PHP Group PHP
Color printer printing out 2 parellel stripes on the paper
clean your printer with a soft brush.....then wipe rollers with a damn cloth...
Oct 06, 2009 | Konica Minolta magicolor 5430 DL Laser...
Switch relay
if you want to do this with parellel with you switch as your starter starts you need your fan relay on .
just do parellel connection with starter.
May 16, 2008 | 1992 Ford Aerostar Extended
Microsoft Office Outlook 2003 for PC Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
