Question about Whirlpool Cabrio WTW6300SB
Wtw6300SWO code dl hum and smell
My washer went through to the rinse and drain cycle, it made the humming sound it usually makes when draining, but then I noticed a smell. There is no water to be seen, but it will continue to hum for several minutes before it says DL. I can only turn it off by unplugging. I started it back up and it poured water and the basket turned back and forth, but when it tried to drain again it only hums until it smells. Does it sound like I need a new drain pump?
  • Whirlpool Master
  • 15,557 Answers
Http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
This has all the tests that you need to run and has information on tech sheets that are included with that machine.
Posted on Feb 09, 2014
2 Suggested Answers
  • 13 Answers
SOURCE: washer control humming
it's always worth replacing the brushes - pattern one's are cheap at around 20 quid so it's just about the cheapest thing to try and washing machines do all mannor of crazy things you wouldn't think were related - like not draining (the water does still drain out but when it hasn't spun properly the clothes are still full of water for instance) worn brushes have a differing effect on difrent washing cycles. the other thing to suspect is the controller -but these are so expensive you can nearly always buy a cheap washing machine for less
Posted on Oct 02, 2012
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Washer control humming
Oct 02, 2012 | Whirlpool Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Whirlpool Cabrio  WTW6300SB Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
