Question about Tools & Hardware - Others
Powershot 5700m So I just bought my powershot 5700m staple gun and it will not work. I followed the instructions for loading the staples. The problem is once I pull the trigger there is no power behind it and the staple simply falls out of the gun and is not forced into the wood whatsoever. Is there an easy fix for this or is this simply a malfunctioning gun?
  • 16,993 Answers
Take it back, the unit is not engaging properly.
Posted on Feb 09, 2014
danny_murray
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
Mike258
  • 1498 Answers
SOURCE: What size staples does the B&G Powershot
Hi Julia,
You have the right size staples. The problem is the length of the refills. Some staplers can't accommodate a full length clip.
Break the staple refill clip in half, then insert it. The shank will be able to close and latch that way.
Best regards
Mike
Posted on Dec 06, 2009
  • 760 Answers
SOURCE: Cannot find staples for this
The ones you have are T-18 I believe
Fires 6 sizes of T50 type staples and drives 9/16 In. brad nails. Visual refill window and easy load chamber. Comfort grip.
•Uses Staples: PowerShot Staples, 97-010, 97-011, 97-012, 97-013, 97-014, 97-015, 97-030, 9/16 In.
•Brad nails
•Ceiltile 17/32 In., 9/16 In.
•T50 type staples, 505TML, 506TML, 508TML, 509, 50CT, 506SS, 504M, 505M, 506M, 508M, 509M, 504, 505, 506, 508, 509
•MFG Brand Name : Arrow Fastener
•MFG Model # : 5700
•MFG Part # : 5700
Posted on Aug 13, 2010
SOURCE: powershot pro staple gun
just purchased a Powershot model 5700m. how do you load the staples?
Posted on Feb 23, 2011
  • 436 Answers
SOURCE: how do you load the
here is the link to manual:
http://servicenet.blackanddecker.com/Products/Detail/5700
good luck
Thanks
Posted on Apr 12, 2011
I have a PowerShot, model 5700M. It jams after firing one staple. It has been trouble since I bought it, just keeps getting worse. I have the correct staples and have never used brads in it. I no...
I was having to pull the spring out or smack it to get mine to fire more than once. I pulled the spring out and pryed the openings apart a little bit with a small screw driver. Works fine again.
Oct 27, 2011 | Tools & Hardware - Others
How do you load staples into the Power Shot Model 5700M staple and nail gun? There is no manual in the package despite direction on the side of the gun to read it!
I have owned a Black & Decker Powershot before. Throw it away. They are **** . Stick with a Arrow or Craftsman. I didn't like the Black & Decker and gave it to a friend that was looking for a staple gun. He threw it away ! Worst excuse for a staple gun I've ever seen. Awkward to use and preforms on a scale of 1 to 10 , doesn't even hit 1 !
Jun 07, 2011 | Black & Decker 5700 Powershot Forward...
I just bought a powershot 5700M Staple and Nail tool. I could find how/where to load the nails. Can you help me?
Hello, W/D here.
I'm not exactly familiar with your model, but have several others, and they resemble yours, so please take these directions as "generic".
Open the fill slide as if putting staples in the machine, making sure that all of the staples have been removed. Insert instead the brads down one staple channel. On my stapler/nailers it is the left channel, facing the gun from the rear. Look carefully on the sides of the gun and the ends as , usually, there is some indication of which channel to use, and you rs may well be the other side. Load and test the gun on some scrap wood. If necessary, change channels and try the other side.
Best regards, -- W/D--
Mar 03, 2011 | Powershot Tool Company PowerShot 5700KB...
How do you load the stapler, powershot 5700m
Here are the scanned images from the Black & Decker 5700 Powershot Instruction Manual. These are just the instructions and corresponding illustrations for how to load the stapler, but the full instruction manual is available here:
http://servicenet.blackanddecker.com/Products/Detail/5700#
Jan 11, 2011 | Black & Decker 5700 Powershot Forward...
Need to put PowerShot Model 5700M together.
Lovenheim posted this diagram on http://www.maybenow.com/ and maybe it'll help you... 8d59edb.jpg
Sep 09, 2009 | Black & Decker 5700 Powershot Forward...
PowerShot staple gun model 5700m is jammed
There is a silver screw near the back bottom (where you load staples) and you must unscrew it. Completely remove the small bolt and the silver base will pop right out. This base is the track where the loaded staples sit while in the chamber. Just remove the jam and re-install in the reverse order. Works like a charm now.
Jul 01, 2009 | Powershot Tool Company PowerShot 5700KB...
Powershot pro staple gun
Oct 13, 2008 | Powershot Tool Company Cobra 8000 Forward...
Tools & Hardware - Others Logo
652 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
