Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Reset lamp timer - Panasonic PT-61LCX65 61" Rear Projection HDTV
Simple answer: -vol button on set and split button on remote hold at the same time
I just figured mine out!!!! So many people with so many different solutions. I read the instructions for the TV, those says to read the instructions for the lamp. I read the instructions for the lamp but this model isn't on the instruction list. For other models it says to use the volume down button on the set and the PIP on the remote. No PIP button on the remote. But wait the bottom row of buttons has a multifunction button for split screen! I tried that and it worked. I had a message that said the lamp timer was set to zero. Done! Hope this helps someone out there.
Posted on Feb 11, 2014
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How do you reset the lamp timer?
    Here's how to reset the lamp timer:
    - Press the Menu button
    - Scroll down to the LAMP TIMER RESET option, then scroll right to enter
    - Confirm that it is OK to reset the lamp timer by hitting the OK button.
    - The on-screen menu should confirm the lamp was reset correctly
    You should only reset it after you've changed the projector bulb.
    Feb 03, 2011 | JVC TS-CL110UAA Projector Lamp
    How does one reset the lamp timer. modelpt-56dlx25
    Panasonic2.gif Lamp timer reset.
    To reset the lamp timer
    For the full instructions and how to reset the lamp timer go to the following site
    http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
    I hope this information allows you to resolve this issue.
    asnowman
    Oct 12, 2009 | Panasonic Televison & Video
    If I reset the timer before replacing the lamp,will the please REPLACE LAMP warning stop appearing???
    Replace Lamp first, then is reset timer come up Go to menu lamp Timer reset.Most of the time TV resets itself after installing New Lamp.
    Sep 21, 2009 | Sharp Televison & Video
    Reser timer for lamp
    I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
    Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
    I hope that helps.
    Mar 02, 2009 | Panasonic PT-52LCX66 Projection Television
    Replacing the projection lamp
    Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
    Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Projection lamp timer reset
    I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
    Jul 19, 2008 | Panasonic PT-44LCX65 Television
    Lamp timer
    From the Vivitek RP51 manual:
    To Reset Lamp Timer please follow these steps:
    1.) Press "MENU" and "VOL ADJ >" buttons on the right hand side of the RPTV for three (3) seconds while the RPTV is on.
    2.) "Lamp Timer Reset" should appear on screen.
    3.) Press "OK" to reset the lamp timer.
    Jul 18, 2008 | Televison & Video
    Lamb will not reset
    Reset The Lamp Timer.
    While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
    Sinista
    Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
    Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
    71 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
