Question about Oceanic Veo 180 Wrist Dive Computer W/backlight & Audible Alarm
Backlight won't work
Very dim green light at 12 o clock position
Clock light is dim or out?
Sounds like you need a new clock. Parts and repairs cost more than new products.
Apr 11, 2015 | Tivoli Model Three Clock Radio
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
LG 32LC56-2C will not turn on, red light establishes after a while but won't turn green
This model was known for capacitors on the 12 volt line giving issues, if your able to change them this should fix it for you, you can buy them online for about a quarter each
Nov 28, 2017 | LG Televison & Video
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
How to hook up pioneer DEH-3200UB radio wat wires r wat
Here's how it goes.
Grey=right front positive
Grey/black=right front negative
White=left front positive
White/black=left front negative
Violet=right rear positive
Violet/black=right rear negative
Green=left rear positive
Green/black=left rear negative
Red=12 volt switched power (work off key)
Yellow=12 volt constant power (direct to battery)
Orange=Illumination (not dimmed by head light switch)
Black=chassis ground
Sep 26, 2010 | Car Audio & Video
The machine doesn't start! The led pause/start is blikkering green or yellow, but I can't get the machine working
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Dec 03, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston L63 dishwasher stopped mid cycle with water in base.
Jun 16, 2009 | Ariston Technologies L63 Free-Standing...
Back lighting
Funny, I've got one I've just stopped using because the backlight is too bright, even set at its lowest.
Maybe we could trade ;-)
Is your's out completely, or just very dim?
Jan 22, 2008 | Timex T150 Clock Radio
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
Oceanic Veo 180 Wrist Dive Computer W/backlight & Audible Alarm Logo
182 people viewed this question
Top Oceanic Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
