Question about Bosch Washing Machines
Display panel on my Bosch washing machine does not work l have checked the out let and confirmed that there is mains power (240V) all the way to the back of the display panel.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
240V does not turn on the display panel you should check the transformer on the board or next to it or check a fuse on the board
Posted on Feb 10, 2014
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Posted on Mar 10, 2010
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
SOURCE: bosch exxcel 1200 express washing
I had F63 on Bosch washing machine (Maxx 7). I waited 5 days for a repairman and all he did was reset the washing machine processor, like this: 1. Turn the program knob to 6 o'clock 2. Hold the RPM button 3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse) 4. Release the RPM button.
This is similar to F21 which also happened to my machine. Apparently both errors are related to power surge/power cut.
Posted on Nov 19, 2010
I have a Bosch classixx 6 1400 express washing machine. My son in his wisdom pressed a few buttons now has F:21 on the display. Do you know how to reset this. Many thanks
Switch off machine for few hours and allow to reset. Now power back and check if the error code is seen, if so there seems to be a fault on the control panel more linked to the motor drive circuit. check to see if the motor is free, hot or humming, if so check the drive for friction, check the connectors.
If these dont solve and the codes are present the motor must be tested separately so as to confirm the fault from the board. Check the power to the board and to the motor.
Feb 24, 2013 | Washing Machines
Bosch wfo2866gb wont work
Possible that the control panel had failed, there is a fuse within the control panel which needs to be checked. Most probably if this fuse has blown there is a short within the board which need to be confirmed for a board failure.
check this link to remove the panel: control panel
Jan 10, 2013 | Washing Machines
My bosch washing machine Maxx classic wont turn on
Please check the main power from the power outlet the mains plug to the controller unit. If there is power then check within for the fuse, if fuse is intact then check for burnt items, if so the board could be damaged and needs a replacement. In most cases if the fuse has blown it is possible that the board has failed and so changing the damaged component could be difficult as the board is immersed in epoxy.
Sep 12, 2012 | Bosch Washing Machines
There is no power going through my Bosch 1200 washing machine. I have changed the fuse but nothing. The powe supply is fine. I have moved on Saturday and the machine was working fine in the morning
In such cases what is needed is to remove the power plug and using a multimeter you must check the continuity of the power to the main controller board. If so connect and check the mains voltage to the board. If the boarrd does not respond you need to remove and replace unless you are an expert to check for component level failure.
click this link for tips : Control board
Jun 26, 2012 | Bosch Washing Machines
Hi, no display on any led. 240v to machine sounds
It does sound as if the door latch may be at fault but it also seems as if it has caused the main control P.C.B. and control Interface to fail.This machine was manufactured in April 2005 from the Prod. no.This is covered under the major parts warranty (not the door latch).Also make sure if the power to the controls is off check for any loose connectors on the main p.c.b and interface.Also have a look at the body of the door latch and if there is a brown discolouration that is a good sign that is the culprit.
May 03, 2010 | Zanussi ZWF1440 Front Load Washer
Bosch 1400 Exxpress washing machine : Turning off after a few sec
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 19, 2009 | Bosch Washing Machines
Bosch Classixx WVF2402GB motor will not run
Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Dec 09, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
