Question about Element Electronics Televison & Video
Have a new Element HDtv and plugged directly into coax cable/cable tv outlet. We don't get all the channels as our other tv that is plugged into cable, but is a converter box for analog to digital and that gets about 40 channels...New HDtv gets 13. Tried rescanning channels and adding manually, but no go. Even changed IRC-STD-etc settings. Help....
    Problem Solver:
  • 6 Answers
Sounds like about all you should get. Clear QAM channels for cable providers usually are limited to shopping crap and locals.
Posted on Apr 12, 2014
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: I had comcast before but
> I had comcast before but now i don't, don't use a converter box and somehow I was getting cinemax and other channels on the tv
Comcast was providing Cinemax and many other channels as part of your paid services and you will not receive these unless you are a subscriber. There is a good selection of free broadcast channels unless you live outside city areas. If you do, you will then need an external antenna and probably an amplifier to get more distant signals. Auto programming will not find the channels you were receiving from Comcast so there will be only accidental channel duplication; for example, if your former channel 10 was NBC, it may be channel 7 when receiving signal from an antenna.
There are essentially no more 'Analog' stations still broadcasting, they are now all 'Digital.' The abbreviations 'Std' refers to the aspect ratio (H/W) of the picture area and 'Hrc' and 'Irc' the available resolution or how many pixels and lines on the screen.
Posted on Aug 28, 2011
After scanning channels tv still does not have picture or sound
What type of input and what type of cable have you set to ?
(a) Antenna - Coax cable (75 ohm)
(b) STB - HDMI
(c) DVD - HDMI or
(d) DVD - Red+White+Yellow
(e) DVD - Red+White+Optical (if your TV and DVD support it)
Most TV cannot find any channel when scanned without a proper external /internal antenna
Aug 11, 2016 | Element Electronics FLX-3211B 32 in. LCD...
I have connecting TV link with coax cable from my sky box to my LG 50PH660V 50-inch Widescreen 1080p TV But I can not get the sky to come on my TV. as channel 68 is DTV and on my remote it says TV/RAD
If I understand your problem the Y splitter is a passive splitter which mean that the centre pins are connected via capacitors this will degrade the picture on one or both outlets, the Sky box should be connected via a scart or HDMI connection
Feb 03, 2015 | LG Televison & Video
WHY CANT I GET HD CHANNELS ON MY ELEMENT ELECTRONICS 32 IN HD TV
To get HD channels you need to have a cable/satellite box that can receive HD channels AND you have to connect that box to the TV with either an HDMI cable or component jacks. A normal cable/satellite box won't work; neither will a coax antenna cable or consolidated video (yellow RCA) plug. Hope this helps!
May 20, 2014 | Element Electronics FLX3220F 32 in. LCD TV
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
How do i get reception with only a cable connection...no box. i don't know what settings to have the tv on.
In the main menu select "CABLE" AND NOT AIR.
With the cable connected to the coax fitting then turn set on and look for AUTO PROGRAM------engage that and the set will scan thru all the available channels.
If it misses any you can with the remote direct enter a channel and in the main menu "add" it to the up down memory.
It is also helpful to "skip" out channels you do not want in the up/down memory-----this is in main menu also.
I usually skip out the Golf channel and others I never watch.
Let me know if you have questions.
Dec 07, 2011 | Toshiba 51H84 51" Rear Projection...
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need to program my tv is cable ready
plse help, i have a cable ready tv hooked up to the coax out of the wall directly to tv and only get 1-13 channels??????
Sep 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
384 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
