Question about Kenmore 15322 / 15324 / 15329 Built-in Dishwasher
CODE F4E1 will not go away
Last week it was leaking on the floor. We fixed the leak by replacing a clamp on the hose. Now we can not get the Code f4e1 to go away. Unplugging the machine for 1 hr did not reset the code.
  • Kenmore Master
  • 17,115 Answers
This error means that the controller cannot communicate with the motor. It is possible that something came loose when you replaced the clamp. Recheck all the connections .
Posted on Feb 09, 2014
3 Suggested Answers
solveditnow
  • 39 Answers
SOURCE: leaks
Check for cracks in the inside liner of the door itself. Seal anything that looks like a potential leak with silicone sealer. I'm providing this advice because you have already eliminated the other possibilities I can think of. If it has a soap dispenser on the door check for leaks around that especially.
Posted on Jan 14, 2009
localwonder
  • 6784 Answers
SOURCE: dishwasher leaking water on the floor
Check the drain hose connection under the washer. make sure the hose hasn't separated form the drain housing. if the drain hose is not the leak spot, move on to the water valve assembly. check the connection there thoroughly. check the seals on the connection hose as well. if all checks out, this will most likely be a faulty water valve assembly.
Posted on Jun 19, 2009
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
My whirlpool washer is leaking from the front center. Happens during spin cycle I think.
Hello.
If your washing machine is leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
    • 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
    • 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
    • 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
    • 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
    • 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
    • 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks.
Sep 03, 2011 | Whirlpool Washing Machines
Leaking at welded fitting on tank? can i jb weld around the fitting
Many have tried same, and only a few have been successful, and at best, only temporarily. Believe it or not, I had 3 do the exact same thing last year, corroded right through the meaty part of the fitting, where you would think would be the last place it would eat through. Being in the RV Service trade, I only want to have to fix it once, and don't want to be responsible for any future floods when away from unit so I replace the tank. I've seen some wild fixes over the years, such as a piece of thick rubber hose over the pinhole with a gear clamp (hose clamp) tightened over it to stop the leak, and it was actually working to stop the leak. Your choice, your gamble, but if you decide to try a quick fix, I'd make real sure I shut the pump or city water supply off when your not going to be close by or in the trailer for any amount of time just in case. Hate to come back from a walk and see water running out the door of the trailer. Good Luck.
Apr 18, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a p0442 code on my 2001 dodge Dakota how do I fix it?
This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Mar 22, 2011 | 2001 Dodge Dakota
Washer leaks from under the front of the machine.
If you are having a problem with your washing machine i.e leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Instructions
  1. Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
  2. Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  3. Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  4. Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  5. Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  6. Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Good luck and thank you and thanks for using fixya.
Jan 30, 2011 | KitchenAid KAWS750L Top Load Washer
2002 dodge carvan shows code P0455 evap emmision system leak gross leak/no flow
That last time I fixed this code it ended up being a leaking EVAP hose on top of the fuel tank. I had to drop the tank and put new sealant on the hoses to stop the leak.
Mar 04, 2010 | 2002 Dodge Caravan
Leaking
Hi
Please Follow this Instructions:-
Step 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks for contacting fixya.com
Oct 30, 2009 | Washing Machines
Water leaking
hi friend,
  • Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  • Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  • Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  • Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  • Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part
  • hope this helps u
    thank u for using fixya
    please rate me.................
    regards
    sivaranjini
    Sep 12, 2009 | Kenmore Washing Machines
    Neon code 455 cant find a evap leak ( gross)
    I have a 2002 Dodge Caravan which had a code 455. The following is a description of this van. The problem was caused by a 12 inch hose located under the van on the drivers side close to and in front of the liquid/vapor separator canisters. The 5/8 inch ID hose was connected between the front (engine side) of the LDP vent valve and the leak detection pump. Oil from the engine had leaked onto the end of hose connected to the pump. The plastic clamp was broken and the hose had swollen until it was very loose. Replacing the hose and clamps fixed the problem. The LDP vent valve is connected to the largest liquid/vapor canister by a 2 inch long hose. You may need to buy the hose from the Chrysler since it is a shaped hose. Any broken or missing clamps should be replaced with the band type sold by auto parts stores. Any other hose which is split should be replaced.
    Jun 26, 2009 | 2001 Dodge Caravan
    Kenmore 15322 / 15324 / 15329 Built-in Dishwasher Logo
    144 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
