Question about Samsung CLP325 Laser Printer
How to turn of toner save - Samsung CLP325 Laser Printer
    Habit-Forming:
    New Friend:
  • Samsung Expert
  • 150 Answers
RESSUME BUTTEN PRESS TO 2 SECOND HOLD
Posted on May 08, 2014
Drum and toner lights are on and both have been rep[laced and page is still shadowed
Have U replaced with Original Drum & Toner.
  • Check the printer's environment. Conditions such as high humidity and high temperatures may cause faint print.
  • If the whole page is too light, Toner Save Mode may be on. Turn off Toner Save Mode in the printer Properties tab of the driver.
  • If Yes please clean the corona wire.
  • Turn off the printer power switch, and then unplug the printer.
  • Press the front cover release button and then open the front cover.
  • Take out the drum unit and toner cartridge assembly.
  • Wipe the scanner window with a dry, lint-free cloth.
  • Put the drum unit and toner cartridge assembly back in the printer.clean_inside91.gif
  • Jun 02, 2011 | Brother HL 5030 Laser Printer
    I Am not abel to switch off the option TONER SAVER ...please help i want to turn it to off.
    1st go in printers and faxes right click on printers icon go properties then go in printing preferences, go in quality tab then u see details tab go and press details in bottom u see use toner save click and u save or not save hope this is working for u thanks
    Nov 16, 2010 | Canon LASER SHOT LBP-2900 Printer
    Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
    If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
    1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
    a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
    b. Press the up or down arrow key to select OFF and then press OK.
    c. Press Stop/Exit.
    2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
    Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
    Print is too light. Replaced drum and toner already. Do I need to clean the laser mirrors. How do I clean the laser mirrors?
    You can't get to the laser mirrors without removing the laser, there is a narrow glass above the drum inside that gets toner on it and needs to be wiped with a soft cloth, also make sure that the toner save is turned off as it makes everything lighter. On the panel select print reports and scroll down to user settings and it will tell you if toner save is turned on.
    Jan 21, 2010 | Brother (DCP1000) Printer
    Where to find "toner save mode" ????
    You can save toner using this feature. When
    you set toner save to On, print appears
    lighter. The default setting is Off.
    a Press Menu, 1, 6, 1.
    Ecology
    1.Toner Save
    b Press a or b to choose On or Off.
    Press OK.
    c Press Stop/Exit.
    Hope this helps
    John
    Nov 20, 2009 | Brother MFC 7840W Printer
    My printer shows ayellow light - toner save-and prints faint
    You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
    Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
    Copier function prints faintly
    Usually the setting that causes that is when you have the toner save function turned on. It saves toner by making lighter prints.
    Oct 12, 2009 | Dell 1600n All-In-One Laser Printer
    My samsung ML 1610 printer, printing very light, even though the toner is brand new.pls someone solve this problem thanks
    There's a button on the top called "toner saver". when you press this is prints light to save toner. Press this once to turn "toner saver" off and print normally..
    Aug 17, 2009 | Samsung ML 1610 Laser Printer
    Light fax
    This could be a couple of different things. The first is that you are running out of ink or toner. Or you could have your toner save turned on. You can conserve toner using this feature.
    When you set Toner Save to On, print
    appears lighter. The default setting is Off.
    1 Press Menu/Set, 1, 6, 1.
    2 Press ▲ or ▼ to select On (or Off).
    Press Menu/Set.
    3 Press Stop/Exit.
    Jan 13, 2009 | Brother IntelliFAX 2800 Laser Fax
    Toner Saver.
    Using the Toner Save Mode
    The Toner Save mode allows the printer to use less toner on
    each page. Selecting this option will extend the life of your toner
    cartridge and reduce your cost per page, but will reduce print
    quality.
    There are two ways to enable the Toner Save mode:
    From the Control Panel
    Press the Cancel button on the control panel. The printer must
    be in Ready mode (On Line/Error green LED is on).
    • If the Toner Save LED is on, the mode is enabled and the
    printer uses less toner to print a page.
    • If the Toner Save LED is off, the mode is disabled and the
    printer prints in the normal mode.
    From the Printer Properties
    You can also enable the Toner Save mode in the Graphic tab of
    the printer properties. For details, see Software User’s Guide.
    Jun 30, 2008 | Samsung ML 2010 Laser Printer
    Samsung CLP325 Laser Printer Logo
    29 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
