Pc 2go login, aafter installing the java, on trying to start-up the 2go app online .....i'll get the notice that my security settings has blocked java application start-up. what do i do?
Security setting blocking my java prog. from starting 2go on pc
  • 39 Answers
chessmaster2
  • 160 Answers
SOURCE: security certificate blocking
http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!1683.entry
Posted on Dec 01, 2008
heavyice
  • 374 Answers
SOURCE: no monitor
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN or DON'T
5) START IT UP...
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE.Hope that will do. Otherwise you can re-install windows if you have a Windows CD.That will definitely solve the problem.There might be problems with VGA Resolution [if you have used the laptop with some other monitor or TV] or driver. For installing Windows Do Google Search.
Posted on Jun 30, 2009
  • 956 Answers
SOURCE: how could i install again
Control panel, uninstall android prog.
Access android web site and download their latest update for your unit.
Posted on May 26, 2011
whyttedragun
  • 14 Answers
SOURCE: we use eee pc by acer, set up the password for the
Okay, first the password problem. Passwords are almost always case-sensitive now, so make sure that your caps lock is in the same state it was in when you first set the password. I have seen it happen that someone will set the password while their caps lock is on, then when they try to log in later with the caps lock off, they get a wrong password error. More often, though, is the opposite. You set the password with the caps lock off, and are trying to log in with it on.
The second problem is a little more complicated. First of all, the file InfraRecorderPortable_0.52.paf.exe is an installation file, which means it won't do the CD burning as it is. If you want to use the portable version of that software (for example, you have a friend that doesn't have that program on their computer, and they don't want it installed, but you still want to use it)you'll have to run the program and when it asks where you want to install it, select your USB stick. It should be able to run from there without any other supporting programs.
Posted on Jun 20, 2011
  • 156 Answers
SOURCE: i pressed block in youcam application when the noticification appeared in lenovo
If you need to remove youcam from start up do the below steps correctly.
1. click on start menu
2. click on run
3. in that window, type "msconfig" without inverted comas
4. continue with the prompt
5. in the system configuration utility, select" startup"
6. untick youcam/cyberlink software
7. click apply and ok
8. restart the system.
Hope this helps
Posted on Dec 03, 2012
I can't login into 2go. If I do it will tell me that if I can't login visit wap.2go.I'm why is that and I use an apple iphone 3gs
The reason it keeps bringing that error page is because U might be getting either ur “Username or password" wrong. Try inputting the correct login information; but if you can't remember your info.... visit 2go.im
Jul 11, 2013 | Android Apps
I cant acess my 2go on my phone it keeps on failing
  1. Want to run 2go on your pc? Similar to the old way of running MXit on your PC with Mpowerplayer you can do the same to run 2go on your PC.Follow these three steps to run 2go on your Windows PC:Firstly you need to download Java. This is quite a big download so it might take a few minutes to download. Java is needed to run Mpowerplayer.Now download Mpowerplayer the java emulator.Then open wap.2go.co.za and download Nokia Generic You will now be able to run 2go on your pc. Are there any alternative to running 2go on your pc than using Mpowerplayer?
Oct 10, 2011 | Toshiba Satellite U305-S5097 Notebook
How to download 2go on tecno
2go.co.za u ll download it there
Sep 08, 2011 | Facebook Apps
With my samsung impression i can download 2go but i cant connect to 2go please send me the settings
With my samsung SGH A877 impression i can download 2go but i cannot connect 2go,please send me the settings so that i can connect with 2go
Aug 05, 2011 | Samsung SGH-A877 Impression Cell Phone
My phone is refusing to login on 2go
Then you need to check the network settings of your phone and secure that the internet of your phone is working perfectly fine, that way your phone will be able to login on 2go. Ensure the browser is using the networks internet settings as the default settings, then you make sure that the login name and password are correct, be sure also that it is the Sim that was in the phone when you registered for 2go that is in the phone when you are trying to login, if not it will not login you account on 2go.
Hope this information helped you.
Jan 11, 2011 | Nokia 6500 Slide Cellular Phone
Help, i want to have 2go on my pc,instead of mobile
  1. Firstly you need to download Java. Java is needed to run Mpowerplayer.
  2. Now download Mpowerplayer the java emulator.
  3. Then open wap.2go.co.za and download Nokia Generic
Nov 05, 2010 | Toshiba Satellite U305-S5097 Notebook
Java Issue Wont work
Open Internet Explorer>Tools>Internet Options>Security>Custom and scroll to see all of the Java enable check boxes. Check what you need, click on 'Apply', when it asks you are you sure you want to change security levels say OK! ~Steve Medley
Nov 06, 2008 | Microsoft Windows XP Professional With...
Java Applications Not Working On My Cingular Se 810i
i understand ur problem , but it has been very frequently noticed that most of the application available on net are not compatible with Sony Erricsson handsets...plz make sure that the apps u r trying to install are compatible for ur phone , it is a clear java version mismatch...
Oct 14, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Java Applications Not Working On My Cingular Se w810i
Oct 11, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
