Question about Fujitsu 24C1 Air Conditioner
Anyone know what a Reactor does on a Fujitsu Air Conditioner?
Both red and white wires run to the reactor I think before the compressor
4 Suggested Answers
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
SOURCE: fujitsu a/c ast24rsg-w blows fuse after 3 mins as comp starts up
My unit is doing the same thing. Have you found a solution yet?
Posted on Jul 20, 2009
How to fill fresh water tank on 2016 evergreen 25fs reactor.
2 ways ..there should be a hidden hose outlet to fill the 106 gallon tank on outside.. have you checked near the gray water extraction location..
other way find the underbelly tanks and trace hoses till you find it..
Sep 19, 2017 | Air Tools & Compressors
How to fix reactor
Nuclear reactor?
Sep 06, 2017 | Cars & Trucks
Compressor running but fridge not cooling
Are you SURE that the compressor is running? That is the motor enclosed in a silo that looks like the containment chamber of a nuclear reactor.
If the compressor is running and you have no cooling, then I suspect you have lost your refrigerant or you have an internal blockage in the unit's plumbing preventing the proper flow of refrigerant.
Mar 29, 2017 | Refrigerators
REACTOR TECHNOLOGY
Which posted question? Do you have a question about reactor technology?
Jun 17, 2013 | Computers & Internet
How do i set this watch?
follow this link and download instructions:
http://www.reactorwatch.com/care_use.html
Rate me, please.
Aug 01, 2010 | Reactor Watches Reactor Reactor Heavy...
561CJ060-a bryant air conditioner two control wires disconnected
Sorry if I am answering this 2x. If it is just A/C then the red and white probably go to the coil for the contactor that cuts on the fan and compressor. If it is a heat pump then they probably go to a circuit board. Red to R terminal and White to W1 terminal. Let me know what you find.
May 03, 2010 | Heating & Cooling
Fujitsu a/c ast24rsg-w blows fuse after 3 mins as comp starts up
It sound like you have a direct short in the compressor ,Usually it means you have a bad compressor,but sometimes it could be a loose wire or bad outdoor motor. Ive installed about 10 of these units and still have yet to have a bad compressor.It could also be a bad circuit board in the outdoor unit.I wish I could narrow it down better but thats my best guess!Thanks ---Nate
Jul 14, 2009 | Fujitsu 24R1 Air Conditioner
I want to know the conection between the thermostat and the fan and compressor in the central air conditions
r and rc @stat to r on furnace
w @stat to w on furnace
g @ stat to g on furnace
y @ stat to y on furnace
from furnace 2wires going to out side unit typical red & white wire. red goes to y @ furnace and white goes to the neutral of the trans former . BE SAFE turn off power.
r = Red wire Hot
w= White wire heating
g = Green Fan
y= yellow cooling
if their is a B or C @ the furnace terminal board that the neutral . Tom
Jun 14, 2009 | Fujitsu 24C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
