Regency scanner model d310
How do i program a regency d310 scanner?
2 Suggested Answers
SOURCE: I dont no how to program my regency z30 scanner
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you wish to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Posted on Sep 28, 2009
How do I program a regency uhf/vhf c403 scanner
Is this a Regency ACT-c403? If so, it is not programmable. It uses crystals to receive the frequencies. This type of antique scanner would be fun for us "old guys" to own, but has no real value. It is something I call bragging rights to own older radios, etc. Fun to talk about over coffee.
Here is a list:
http://radiopics.com/Scanners/Scanners/Regency/Scanners.htm
Mar 20, 2018 | Radio Communications
Where can I buy an antenna for a Regency model R1070 scanner
search ebay for "regency r1070 scanner antenna" and many will pop up. Also Radio shack..
Jul 09, 2012 | Uniden Radio Communications
This is not my product I have a Rca four band scanner (old) model # 16S400 need a manual for programming freq
The RCA 16S400 is not a programmable scanner. Rather, it's an old (70's) crystal-based scanner that requires one crystal for each frequency. It covers the VHF-low, VHF-high, and UHF bands, and utilizes Regency type crystals. You can do a Google or Yahoo search for the crystals, but eBay is probably the best, and lowest priced source.
Bill B.
Listening in since the 60's
Oct 13, 2010 | Radio Shack Pro-96 Scanner
Need a manual to program radio freq for a RCA four band veractor tuned scanner, this is not a gps but a radio scanner model # 16S400
Please excuse me if I've already answered your question -- it sounds familiar. The RCA 16S400 is a 70's-vintage crystal based scanner that covers the VHF-Low, VHF-High, and UHF bands using frequency-specific crystals. It is not programmable, but rather requires one crystal for each frequency to be scanned/tuned. It uses Regency-type crystals which can usually be found on eBay at reasonable prices.
Bill B.
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
Uniden sc230 scanner
The lock out function is a common problem in scanners, to override the lockout command, you can press and hold the lock out button, or punch in the frequency that you locked out and unlock it by pressing the appropriate buttons depending on the model of your scanner. Here is a suggestion, for easy scanning I recommend a Regency Touch K500 Scanner. It may be hard to find one though, Regency went out of business a while back, but I had the K500 and it was the best scanner I ever had.
Mar 22, 2008 | Uniden BC72XLT Handheld Scanner
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
76 people viewed this question
k24674
jasbo
jasbo
