Question about Cam Spray 3000QD* Q Series 3000 Psi Diesel Hot Water Gas Pressure Washer
Cam spray 3000qd when I turn on heater flames shoot out and then flames go out and I get a lot of smoke. I get hot water for a few seconds then just smoke.
  • Cam Spray Master
  • 16,987 Answers
The diesel fuel pump is bad, replace it.
Posted on Feb 09, 2014
The flame in my noritz tankless water heater turns off when I lower the pressure of water flowing from the faucet (however when the flow of water was at high pressure the flame never turned off). This also...
has this heater always acted like this? if so
you need to supply heater with the right water pressure or flow
try cutting back by turning inlet valve off to restrict flow or restrict flow on hot end. hope it works it did on mine
Dec 30, 2014 | Water Heaters
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
I have a Paloma PTG-74PVN-2 and we have to turn the hot water on for 2 seconds snap it of and back on for 2 seconds repeat this 5 to 6 times in order to have the hot stay on. If we turn it on once the...
I think you will find that the problem is in the flow sensor and that those problems are causing the gas alarm problems...
By slamming the water on and off you are able to get the flow sensor to finally stick in the closed position and keep the flame on...
Replace the flow sensor or have it replaced and I think it will solve your problem...
heatman101
Jan 08, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Reddy heater 70,000 with factory thermostat will run a few
Set the pump pressure. If correct check the nozzle. Desa recommends annual replacement.
A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics.
Dec 12, 2008 | All-Pro Forced Air Kerosene Space Heater...
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Cam Spray 3000QD* Q Series 3000 Psi Diesel Hot Water Gas Pressure Washer Logo
93 people viewed this question
Top Cam Spray Garden Experts
John Trevino
russlakeside
Level 1 Expert
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
