Question about LG WM-2277HW Front Load Washer
Lg tromm wm2277hw will not spin - LG WM-2277HW Front Load Washer
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Posted on May 04, 2016
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
SOURCE: lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Posted on Mar 06, 2008
  • 4 Answers
SOURCE: LG Tromm WM2277HW will not spin both directions, LE error.
Short answer: The post+images by “chem-prof” on Jan 10, 2008 and the post with part instruction by “wolfster” on Dec 04, 2007 solved the problem!!! You guys are the best!!!
Long answer: We purchased the LG WM2277HW three and a half years ago. We have been VERY happy with the results. Last Thursday we got the LE error code after placing a single sofa cover in for a quick cycle. I’m not sure if this is what caused the part to go bad or it’s just the fact that this part might have a “time limit” so LG can make more money on service… (sounds like my Volvo!!!). Anyways, after freaking out for five very long minutes, I Googled the phrase “LG Tromm WM2277HW will not spin” and got directly to this page (WAHOO, FixYa.com!!! You guys are great too!!!). Read the instructions posted by “chem-prof” and “wolfster”. Following “wolfster” I went to download the user manual and exploded diagram from http://136.166.4.200/contents/Laundry/WM2277.htm, then I went to http://www.mcminone.com/ and typed “P/N 6501KW2002A” in the search. Got the “sensor assembly” part for $17.50 + $22.50 (2nd day air UPS). Make sure to note “Please send me a UPS tracking info” in the comments field. Got the UPS tracing e-mail from mcminone.com and waited…. Tuesday was my delivery day (Ohio to Florida). On 5pm got the part by UPS. At 5:15pm it was all assembled and first cycle was started to run!!! Now it’s my 3rd cycle and the baby LG WM2277HW is spinning like usual!!!
OK, now let me tell you, the images by chem-prof are great, but I found that if you take the three screws that attach the electric cords to the drambase it will actually make your life easier and it you will not need to disconnect one of the cords/plug, only the small one that attaches to the “sensor assembly”. See my image for the process:
A. Take off the 4 screws for the metal covering
B. Take center large screw (#2 on my list, it was a mistake…), this will not be as easy unless you have someone else to hold the dram from the front… but it’s doable after all, I did it!
C. Take off the magnets covering, this may require some shifting left and right, while pulling to the back (placing it back is not that easy, indeed watch your fingers when placing it back!)
D. Disconnect the cords attachment screws (#1 on my list)
E. Take the 6 screws of the motor (looks like a circle with orange cords around it!) (#3) and place the motor on a towel on the floor
F. Take off the plastic part (“sensor assembly”) from the motor
G. Place the new plastic part (“sensor assembly”) on the motor
-- Redo steps E to A backwards… voualla! You’re done!
H. Take your wife and the kids to a fancy restaurant for all the $$$ you saved!
Posted on Jul 16, 2008
SOURCE: I need the user manual for my lg tromm wm2277hw
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Posted on Jun 20, 2009
rdrsp
  • 85 Answers
SOURCE: lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Posted on Oct 26, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
LG Tromm WM2277HW drum was noisy, then wobbly and now has stopped spinning
Remove back cover and check for a loose nut that holds the rotor. you may have to replace the rotor( is the cover that holds the magnets). Not the stator (which is the motor.)
Apr 28, 2014 | LG WM-2277HW Front Load Washer
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
Jun 15, 2009 | LG WM-2277HW Front Load Washer
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Feb 12, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
55 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
