Question about Electrical Supplies
Honda Es6500 auto throttle not working
I have a Honda ES6500 generator that runs and generates fine. With no load on it and auto throttle on it will not idle down. I unplugged the solenoid and get no dc voltage going to it. I can jump 12vdc to the solenoid and it will idle down. Sound like the auto throttle controller but where is it and how can I check it?
2 Suggested Answers
spekgt
  • 60 Answers
SOURCE: My Honda ES6500 watt generator keeps blowing 15 amp fuse
Hi there .
In my opinion you should remove the starter and check the starter first . After you remove the starter get a good 12v battery and 2 wires and test the starter . Make sure to not invert polarity . After you touch the wires on the contactor (small solenoid on the side) see if the overrunnig (part with gears) comes out easy and with no obstruction . If the overrunning does not come out you could have a bad contactor (part # 31204-ZA0-003) or a bad starter (part # 31200-ZA0-701) .
Hope this help
Posted on Sep 02, 2009
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
Does anyone know how to clear error codes for a honda es6500 generator
Depending on generator the error code is a wrong set governor, or a GFI on the electric side of unit. Push the reset button on the GFI an that should clear it. If not you will need a dealer.
Jan 27, 2015 | Honda Cars & Trucks
Honda es6500 won't start has fire,compression , gas, not voltage at carb, oil light on then goes out when cranking
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Apr 03, 2014 | Honda EU6500iS Inverter Generator
How do i remove the starter on a Honda ES6500 generator
Remove ground wire from battery post. Make sure unit is off too. Remove start wire and cable from starter and both bolts. Reinstall in reverse order.
Feb 11, 2014 | Honda Electrical Supplies
Honda es6500 low oil lamp on engine oil is at upper limt. reset butten did not pop. engtne will not run
If the low oil switch fails, you have to jump the switch for the engine to operate. I have a compressor with that problem. Then either you watch the oil level carefully or install a new switch, which, in my case, requires disassembly of the crankcase.
Gary
Aug 28, 2011 | Honda Electrical Supplies
I need a repair manual for a Honda ES6500 generator, can you tell me were to find it.
Try ebay thats were i go to find a hard to find manual. Hang onto that generator those es 6500 s are hard to come by . Hope this info helps
Nov 01, 2010 | Honda Electrical Supplies
Honda es6500 runs fine but power goes in and out, barely runs a leaf blower and then full speed for a minute or two. any suggestions? glen57
Check for loose brushes on ring contacts for the alternator rotor. Also, make sure the rings are bright and not oily.
Sep 14, 2009 | Electrical Supplies
Hi there .
Hope this help
Aug 27, 2009 | Electrical Supplies
Electrical Supplies Logo
228 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
