Question about Magellan eXplorist 300 GPS Receiver
Magellan Explorist 300 Keypad doesn't make contact
5 Suggested Answers
SOURCE: LCD screen magellan explorist 210
you are welcome , but send me detailed photo of that lcd
Posted on May 06, 2008
  • 5 Answers
SOURCE: Screen is out
A black screen, actually purple, means that a firmware upgrade was unsuccessful. You can try to fix it by reloading the firmware, but you are most likely not going to be successful using the USB 'binary'firmware that is available.
There is some 'text' HEX firmware available on the yahoo Explorist user group. To use it though, with your USB cable, you will need to make a small circuit with 1 chip. That site shows how to do it. I am in the process of doing that for an Explorist 400 for a friend. Others have said this is the only to recover such a lost GPS. I'll keep you informed of my success when it happens. I'll probably be sending the circuit/cable I build along to other friends but could possibly fix your for you if you like.
Posted on Feb 26, 2009
SOURCE: replacement parts for Magellan eXplorist GPS
You need to be brave, but it is pretty simlple. Basically you are going to clean the rubber keypad and circuit board contacts. These contacts develop a film over time that needs to be removed. That is the main reason telephone and remote control keypads fail over time.
1. Remove the battery.
2. Remove 5 screws holding the bady together and separate the backplate from the main body.
3. Now carefully lift the circuit board out of the main body. Do not disconnect anything, but be careful with the rubber seal that fits between the back and front plates.
4. With the circuit board laying flat on your work surface, remove the rubber keypad. It is held in place over the joystick. Carefully lift it off the joystick and set it aside.
5. Use a clean pencil eraser and lightly rub the contacts on the circuit board. Do the same thing on the keypad by pushing the little knobs out where you can rub them. Blow away the dust.
6. Use a Q-tip with some alcohol to clean the contacts on the curcuit board and on the keypad.
7. When the alcohol is dry, put everything back together in the opposite order.
This should be good enough, but if it does not solve the issue, then buy a rubber keypad repair kit (an example is at http://www.mgchemicals.com/downloads/appguide/appguide0206.pdf) and try again.
Good luck.
Posted on Apr 27, 2009
SOURCE: magellan explorist 400 gps won't power up with usb cable
fhfj
Posted on Jan 31, 2010
My Explorist 210 does not connect with any computer. What can I do.
What is happening is your computers are not recognizing your unit. Means you have to update unit via the registered site for updates.
first Perform a hardware reset to return the minor settings of the GPS to the original condition. Press the small "Reset" button on the side of the unit for several seconds until it powers off and powers back on.
If that doesn't solve the problem, then it means you will have to perform a firmware upgrade to put the GPS back in order.
Download and install the Content Manager software available for free from the Magellan support website. Connect your GPS to your computer with a USB cable, and the software will automatically search for firmware updates for your GPS.
Here is support to copy and paste in your browser for Magellan.
http://support.magellangps.com/support/index.php Thanks Mike
Oct 05, 2011 | Magellan eXplorist 210 GPS Receiver
My Garmin Explorist GC freezes upon startup (Garmin logo, no rotating stuff). I have tried the 3-button (menu, joy up and power) solution suggested by some, with no luck. Any ideas??
The Explorist GC is made by Magellan.
You may want to contact Magellan support for assistance.
http://support.magellangps.com/support/index.php?group=default&languageid=1
Sep 17, 2011 | Magellan eXplorist GC Handheld Geocaching...
The gps was dropped and the inner screen is broken, can I get it repaired and how much will it cost?
You can try to assemble a new screen
http://cgi.ebay.com/Magellan-eXplorist-100-200-210-300-400-LCD-Screen-/350445109117?pt=LH_DefaultDomain_0&hash=item519827ff7d
or send you damaged one to magellan and purchase a new or refurbished one at a discounted price.
http://www.magellangps.com/s.nl/sc.56/category.332/.f
Mar 11, 2011 | Magellan eXplorist 100 GPS Receiver
Need new screen for magellon explorist 100 gps
http://cgi.ebay.com/Magellan-eXplorist-100-200-210-300-400-LCD-Screen-/350437050321?pt=LH_DefaultDomain_0&hash=item5197ad07d1
My recommendation would be simply to replace entire unit unless you have experience fixing electronics.
Mar 03, 2011 | Magellan eXplorist 100 GPS Receiver
Screen is out
Nov 25, 2008 | Magellan eXplorist 300 GPS Receiver
Replacement parts for Magellan eXplorist GPS
Good luck.
Sep 02, 2008 | Magellan eXplorist 400 GPS Receiver
Replacement keypad membrane
If you look on magellan website it states they no longer have or support replacement parts for older gps models.
You can find an explorist for parts on ebay.
I own a explorist 100, 400, 500. I believe the key pads are all the same. If you can not find one, I will sell you the pad from the explorist 100 for 30 dollars plus shipping.
May 08, 2008 | Magellan eXplorist 600 GPS Receiver
Button does not work
if you don't mind taking it apart, carefully unscrew the case and seperate the two halfs (be carefull not to break any of the wires or ribbon connections) , pull off the rubber pad with the buttons, and clean the contacts on the circuit board (you could use alcohol, or I use model railroad track cleaner that you can get at a hobby shop)
Jan 29, 2008 | Magellan eXplorist 300 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 300 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
