Panasonic DVD/VCR combo Player,PV-D4734S
Last week I suffered a power outage.When power was restored my unit did not power on.Ichecked the fuse,it is ok because power is there,and I get readings throuhgout the power circuit,but the front of the unit shows no power and nothing works, can you shed some light.I checked for repair manuals around some shops and the closest I got was Maryland, and 12 days to ship.
  • 4 more comments
  • Bristol Man Nov 24, 2007
    Same Problem as TechPetro: Last week I suffered a power outage. When power was restored my unit did not power on. I checked the fuse,it is ok because power is there,and I get readings throuhgout the power circuit,but the front of the unit shows no power and nothing works.
  • TechPetro Jan 30, 2008
    I will have to look at that diode and take a reading to see if there is a value in that section and the diode itself.Right now I haven't done anything else with the unit.When I will check it and see if
    thats what is the malfunction,I will send a reply and rate the response from your site.
    Sincerely
    Tech Petro
  • leapyear2008 Feb 24, 2008
    I have the same problem for 2 units. Both didn't power on after a power outage. I cracked the case and checked the fuse. But I don't know what might be wrong at this point.
  • ronsilver May 30, 2008
    model pv-d4744S-k no power at all to board checked fuse - ok
  • Anonymous Nov 01, 2008
    After a power failure the unit does not work.
  • bet64des Mar 07, 2009
    After power outage Panasonic DVD/VCR doesn't work, no clock, won't play nor record. Tried other outlets w/o success. Unit only year and half old at the time.
Read a post from tech-net.archive.net for the values:
d1o41 20vz diode - shorted
pr1005 1.5A ic protector - open
Please post if your repair worked!
Posted on Feb 24, 2008
I've got the same model, Panasonic PV-D4734S-K
And same problem, no power at all, high pitch sound from power supply.
I'm working on replacing the Diode, D1041.
It cracked as I was extracting it,
Can anyone let me know what the value of Diode it is??
Thank you,
Frank
s1gear[]yahoo.com
Posted on Jan 27, 2008
Why after power outtage dvd player don't work?
A power surge sometimes fries the unit it may have a fuse you can replace on the inside
May 14, 2015 | Magnavox Dv220mw9 Dvd Vhs Vcr Combo Player
I need the code for my one for all remote URC-3021 for my panasonic VCR/ DVD player model # PV-D4734S
If your remote is programmable, you can use its "code search" feature to seek a suitable code. If your search is unsuccessful, you may need to try a different remote.
Aug 18, 2014 | Televison & Video
How do i convert vhs to dvd with panasonic pv-d4732
This unit is a DVD player only it will not record a DVD
Feb 24, 2013 | Panasonic PV-D4732 DVD Player / VCR Combo
Describe your Panasonic PV-D4743 DVD Player / VCR Combo Problem I DO NOT HAVE REMOTE FOR THE DVD/VCR. WILL A UNIVERSAL REMOTE SOLVE THIS? I HAVE A SHARP TV WHICH ALSO LACKS A REMOTE.
Universal remote may give you few controls like power on-off, FF, REW etc but Menu may not open.
Substitute remote for this Combo is available in Remotes.com and original remote is available in Panasonic Parts under part number LSSQ0374
Same thing goes to your Sharp tv.
Thanks.
Jul 02, 2011 | Panasonic PV-D4743 DVD/VCR
I have a 6 year old panasonic PV-D4734S thais probably not used more than 10-15 hours per year. When I tried to turn it on a few days ago, nothing happened. I opened it enough to check the only fuse I...
No power at all from the unit? there is likely to be a fault in the switchmode power supply, which can be caused by any number of components, including leaky electrolytic capacitors. With any SMPS service, all the caps must be replaced together to ensure reliability, along with any IC regulators and diodes which may have been damaged by the faulty caps. If the PSU also features a chopper transformer, this may have an open-circuit winding. Either way, this would require workshop attention by a qualified technician with adequate equipment, and access to replacement parts.
Best option is to submit the unit to an authorised service centre, obtain a quote on the likely cost(s) involved, get a second opinion; then you can make a firm decision on whether it is economical to pursue the repair or not. Up to you.
A dead machine is not always just a simple blown fuse. The cost of the repair will depend on the extent of the original failure in the power supply and whether it has affected anything else in the unit.
Apr 02, 2011 | Panasonic PV-D4734 DVD Player / VCR Combo
Need Code
What is the model number of your remote?
Jul 17, 2008 | Panasonic PV-D4753S DVD Player / VCR Combo
VCR, DVD PLAYER
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
Apr 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote code
Some remotes, such as the Sony RM-VL600, have a learning function that will "learn" the code for your set.  I used one for my combo unit, and it worked OK for the TV functions, but I couldn't get it to work for the DVD player.
Mar 06, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Televison & Video Logo
1,164 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
