Question about Magnum 2006-2007 dodge se 2.7l a/c compressor clutch
BOTTOM OF MOTOR WAS SHOOTIN OFF SPARKS AND GLOWING
  • 3,103 Answers
Time to go get it fixed..dontcha think??
Posted on Feb 09, 2014
What is a cylinder compression
cylinder compression: the occurrence of where fuel goes into the engine or motor and the cylinder comes back up compressing against where its ignited by a spark plug or glow plug (defers to two types of engines or motors) as the spark happens this occurrence refers to a stroke as the cylinder goes back down from the force of the explosion inside the motor block (check wiki or youtube for more info)
Aug 22, 2017 | Cars & Trucks
What is the electrical part on bottom of carburetor and what does it do
Some lawn more motors include a anti dieseling l solenoid to restrict fuel from entering the carburetor after engine shut down. The technical name is "anti-afterfire solenoid"
When the key is turned on the solenoid retracts allowing the gas to enter the engine as the engine is cranked. When the engine is turned off and no spark condition the engine can continue to run igniting the fuel from a glowing combustion chamber (like a glow plug engine). This device prohibits fuel from continuing to enter the Carburetor after the key is turned off, No spark, no fuel engine will stop.
Nov 25, 2015 | Garden
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
How to fix 2004 Infiniti G35 window motor
Look at parts store websites and eBay for a replacement window regulator. You need the whole shootin' match, not just the motor. When you get it, take it to a glass shop and pay them 50 bucks to put it in for you.
Feb 08, 2011 | 2004 Infiniti G35 Sport Coupe
Wont start
Shootin in the dark. I suspect there is a faulty ground between the engine and the body. Try a jumper cable. If no go, then check for fuel an spark. Really need more info.
Apr 16, 2010 | 1999 Chevrolet Silverado 1500
BAD COLD START NEW GLOW PLUGS STILL BAD START GLOW PLUG LIGHT STAYS ON
You have to check if you really glows comes to power that can show you the light on the dash that are working and maybe the relay of the glows does not work and you will pass voltage. Try a thick cable you put something in the battery positive and the other end touch the tip of the glow should produce a spark pquena holds about 20 or 25 seconds and give him star should work well. Thanks
Feb 27, 2010 | 2003 Renault 181
My 2006 electric glide a 1300 has been runnin bad
The most likely cause is moisture trapped inside the spark plug caps. Slide each one off of its spark plug, then spray inside the cap with WD-40. Do the same for the end of the spark plug where the cap goes on. Remove the excess WD-40 with a clean paper towel. WD-40 is non-conductive and will remove the moisture (which is highly conductive).
Nov 27, 2009 | 2006 Harley Davidson FXDWGI Dyna Wide...
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Magnum 2006-2007 dodge se 2.7l a/c compressor clutch Logo
35 people viewed this question
Top Magnum Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Magnum Air Tool and Compressor Expert? Answer questions, earn points and help others
