Question about Whirlpool Cabrio WTW5500X 27" Top-Load Washer with 3.6 cu. ft. Capacity, 9 Wash Cycles, 4 Temperatue Settings, 800 RPM Spin Speed and Stainless Steel Drum
Washer wont agitate - Whirlpool Cabrio WTW5500X 27" Top-Load Washer with 3.6 cu. ft. Capacity, 9 Wash Cycles, 4 Temperatue Settings, 800 RPM Spin Speed and Stainless Steel Drum
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
Jun 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Amana heavy duty washer wont agitate with clothes in the washer
please post your model number for futher assist...
Apr 07, 2009 | Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW5500X 27" Top-Load Washer with 3.6 cu. ft. Capacity, 9 Wash Cycles, 4 Temperatue Settings, 800 RPM Spin Speed and Stainless Steel Drum Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
