Question about Altec Lansing New Original Dell ADA995 5.1 THX Certified Sound Speaker 4J133
How to hook up ada995 to laptop pc usb port?
The 5.1 speaker system has 3 cables (green-yellow-black); laptop has usb ports.
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Plugging the cables to the motherboard
Hello my friend, try to scan your motherboard manual to find the detail information of the different parts of the motherboard.Also the basic ports of motherboard is the USB port, PS2 port (green - for mouse and violate - for keyboard) LAN Card Port, Audio Plug (green - audio out for speaker, headphone, pink for mic, black or blue for other  audio plugs), Onboard VGA card plug (Color Black for female plug Silver for Male Plug) Serial Port for printer. Hope this information help you.
Jun 18, 2009 | Microsoft Windows Vista Home Basic for PC
2 SET OF SPEAKERS WON'T WORK FOR ACER E380
Do these speakers came with the system? If yes then check your manual from the Acer's website ( www.acer.com)
Also what color ports do you have in the back of the Desktop?
I believe you have a green, a Blue and a pink port, the Green is for outgoing sound, the Blue is for incoming sound, like a tape player recorder or a External CD player to get sound to your PC, and the PIN is the Microphone.
Feb 11, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
LOGICTECH X-530
That speaker equipment should've came with an adapter to audio cables
its a rectangle that has 3 ports (orange,black,green) that lead out to 2 ports (red,white) from there u need the audio cables or AV cables
connected the red/white prong to the red/white ports on the adapter.
then connect the other end to the back of the tv where you will c white yellow and red
for dvd player connect it to the white and red ports
dont wry about the yellow 1 that is for video
Oct 18, 2008 | Logitech X-530 Computer Speakers
Acer computer speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Jan 06, 2008 | Acer 90.00012.30B Computer Speakers
Altec Lansing New Original Dell ADA995 5.1 THX Certified Sound Speaker 4J133 Logo
919 people viewed this question
Top Altec Lansing Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Altec Lansing Measuring Tool and Sensor Expert? Answer questions, earn points and help others
