Question about GE Computers & Internet
Bazoo keyboard DRIVER - GE Computers & Internet
Numbers not working
The motherboard on your laptop is not the problem. It is the driver. If it was the motherboard the keyboard would not be working at all.
The keyboard driver is corrupt. Disable keyboard driver then uninstall keyboard driver.
NOTE : This will stop the keyboard from working at all make sure you find the correct page to download the correct driver, or have the correct driver for the keyboard on CD before following this procedure.
Scan for Hardware Changes and reinstall the keyboard driver.
Restart the computer.
The numbers should work now.
Just to be on the safe side, you might want to run a full virus scan.
If this does not work I would suggest that the ribbon cable connecting the keyboard to the motherboard may be loose. If you know how than you can fix this yourself easily. If you prefer you can take this to a repair shop and it should cost no more than 20 pounds to fix. It is just a case of opening up the front of the laptop and securing the cable.
Sep 20, 2013 | Compaq Keyboard
Hp ny419aa keyboard driver
Hi icpfreak6669...
Your keyboard does not have a driver, it is the computer that has the driver for your keyboard.
Your keyboard driver will be located on the HP website...
You will have to put your model number of you computer in at this website...and follow the directions to download your keyboard driver.
Bud
http://www8.hp.com/us/en/support-drivers.html
Sep 23, 2012 | Computers & Internet
Your Sony Vaio VPCEA13EN keyboard Problem Key board not working properly - tyPes d Letters I O P as 5 6 *, J K L as 1 2 3 , M as 0 etc
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Dec 30, 2010 | Sony VAIO VGP-WKB1 Keyboard
Loard drivers
hope this helps
Dec 28, 2010 | Sakar 62150 Keyboard
The keyboard has batteries, but will not work. The mouse works fine
hope this helps
Dec 21, 2010 | Acer NSK8458AN Keyboard
Keyboard not working
hope this helps
Dec 06, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
Keyboard connects (num lock light comes on) but can not type
keyboard connects (num lock light comes on) but can not type it indicate u'r hardware is OK ,but driver need to be installed
if u give me acces to your pc by teamviewer i can solve
Dec 03, 2010 | Computers & Internet
I have got an keyboard of your brand and i have purchased warranty. Now the keyboard stopped working.
make sure you have the driver for the keyboard before uninstalling the?driver
hope this helps
Nov 27, 2010 | Computers & Internet
Space bar not working
or
hope this helps
Nov 25, 2010 | HP D8597A Keyboard
How do i set the keyboard back to default settings ?
hope this helps
Nov 09, 2010 | ASUS Eee PC 1000H Laptop
Computers & Internet Logo
83 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
