Question about Apple iPhone Cell Phones
I want to charge my iphone but i dont have my charger
  • 3,103 Answers
Well that means you either need to get one or borrow somebodys.
Posted on Feb 09, 2014
My iphone won't charge
Please try your charger with another iphone.
Try a friends charger with your iphone.
If your charger charges your friend iphone, your charging port may be bad.
- If your friend's charger works with your phone, then your charger may be bad.
Mar 30, 2014 | Apple iPhone Cell Phones
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
I dropped my iphone 3gs and now it wont charge and middle button doesn't respond. Before the charge went out, everything else was working.
Your iphone 3gs home button disturbed cause of falling, the charger pin n home screen button closely arranged...
Try to service your Iphone in a apple authorized service centre...
Dont try to service with unauthorized people...
Sep 17, 2010 | Apple iPhone Smartphone
Iphone won't charge
is it brand new? plug it first on your computer then after setting the phone up, it will charge with a wall charger. it could also be that you're using an incompatible charger. a higher version of an iphone, say the 3gs won't charge if you use a charger that is meant for a 2nd gen iphone or lower only.
Jul 25, 2010 | Apple iPhone 3G
Well, my iphone was charging, and my baby sister pulled the charger straight out the charging plot in the iphone with force and now it wont charge what shall i do now?
Check if the pin on the Iphone or the charger is damaged. Try using a different charger or try charging it with the USB cable with the computer.
Feb 26, 2010 | Apple iPhone Smartphone
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
IPhone dont turn on
Keep the home and power button pressed for 10 seconds, then, leave power and keep the home button pressed...shud be able to see the charging cable logo...then restore it...
Jul 05, 2009 | Apple iPhone 3G
My iphone doesnt charge
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Oct 11, 2007 | Apple iPhone Smartphone
Cell Phones Logo
15 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
