Question about Microsoft TIGER WOODS PGA TOUR 13 360
No putter availble - Microsoft TIGER WOODS PGA TOUR 13 360
2003 Pontiac Montana puttering mainly in the morning, or randomly. changed the fuel filter, mass air flow and fuel pump relay, still puttering, HELP !!!
Explain puttering ! never heard that one before , an I've been fixing automobiles for over thirty years ! An it's not a term GM uses . Misfire , surges or chuggles ,hesitation .What you should do is take it to a reputable ASE certified repair shop an have them do a diagnostic check with a factory or equal scan tool .
Sep 17, 2015 | 2003 Pontiac Montana
Fixing a worn-down putter face
most golf stores can replace the face plate for about $25 but you can buy the part and do it yourself part $7 and a bottle of contact cement $3
Sep 04, 2012 | Odyssey Steel 2 Ball Srt Putter
1999 JImmy after vehicle sits over 3 hours I start (not a problem to start) it will idle at 500 RMPs and start to putter and putter. If I hit the gas it will go to 3000 RPMS with no problem then once I...
Try cleaning the throttle body (throttle body cleanner ONLY). Uncover the TB (engine off) & inspect the butterfly by moving the throttle by hand, if the underside & down inside the TB has a bunch of carbon (black soot) that could hamper with the idle! Also, check the fuel pressure @ the rail, under 60 psi could cause bad idle. Air filter clean? Did you make SURE that the terminals under the spider injector wiring harness has NO pins bent over during connection?! Also could check the throttle possition sensor & the mass air flow sensor if need be.
Aug 25, 2010 | 1999 GMC Jimmy
Scuti Biglite Putter Grip -: after having grip installed and setting over night...
Use 3 to 4 layers of double sided tape instead of 1. Also Allow 48 hours to dry.
May 17, 2010 | Orange Scuti Biglite Putter Grip -
Where can i get replacement white disc's for my 2
where can i get replacement white disc for odyssey 2 ball putter?
Dec 14, 2009 | Odyssey Steel 2 Ball Srt Putter
I am trying to remove the shaft from an Odyssey 2-ball putter and can't get it off. I have used a heat gun and a tourch to no avail. It appears to be an "over the hosel" attachment but none the less the...
Rosemary, I found a broken Ping putter in the trash can and took it to a golf repair place and they put a new shaft in for not too much money and it was a great putter for many years before I needed a belly putter to help me keep the putter more steady.
Nov 13, 2009 | Odyssey Steel 2 Ball Srt Putter
Is puttering and is not as powerful as it was. I
Carb is all gummed up. It will need to be taken apart, dismantled, and cleaned out. Soak in solvent for couple hours. Also check that spark is good. If weak, sand flywheel and coil with emri cloth.
Sep 13, 2009 | Garden
Microsoft TIGER WOODS PGA TOUR 13 360 Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
