Question about HP Compaq Presario CQ57 Laptop
Keyboard on HP Compaq Presario CQ57
When typing in and I hit the space barthe contrl panel appears for system security and system,also when I hit backspace bar a panel appears stating computer only,duplicate,extend,projector only,and also switches from normal screen to magnified screen and also when the spacebar is hit the printer screen appears,Please could someone help me I have restored it to the factory settings and it still does the same thing.
    Top Expert:
  • HP Master
  • 26,196 Answers
Possibly the Fn key is switched on.
Posted on Feb 09, 2014
Pyrhyc
  • 2028 Answers
SOURCE: HP Compaq NX960 Laptop Keyboard Problem
This is generally a sensitivity issue with the keyboard. It's usually caused when the rubber depressors that activate each key start getting worn. Sometimes you can take each key off individually, take off the rubber depressor and clean the contact point on the keyboard and up inside the depressor where it makes contact. Clean it with with rubbing alcohol and Q-tips. This is alot of work and only fixes the problem about 60% of the time. Your only other option is replacing the keyboard.
Posted on Jul 23, 2008
Dipu007
  • 2110 Answers
SOURCE: want to restore compaq presario to factory settings
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
this doc may help u ...
Posted on Dec 08, 2008
zohail
  • 1223 Answers
SOURCE: how can I restore to factory settings
Compaq/HP: When you first turn on the laptop and see the Compaq/HP logo screen, press the F11 key (you need to do this before the Compaq/HP logo disappears).
pls rate well
Posted on May 07, 2009
  • 25 Answers
SOURCE: how to restore to factory settings presario cq50
2 possible solutions to this
1. Use the roll back function of your operating system to roll back to the last back up.
2. Insert your restore disk or Windows disk and do a format/clean install.
If you have a restore disc it will have prompts to "restore" your system and give you a warning about losing data-save off what you want BEFORE doing this restore
If you have standard windows disk you may want to use the format utility in windows first to clean the drive and do a fresh install.
Once installed don't forget to download updates and back up and then reload your other software.
have fun this will take several hours depeneding on the amount of stuff you have to reload and patch up.
Posted on Oct 26, 2009
SOURCE: hp dv7 keyboard issue
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
Posted on Jan 26, 2010
How to turn on keyboard backlit on Compaq CQ57 laptop?
CQ-nnnnn what is nnnnn , may Cq57 made, all different nnnnnn
QC-100,.-200.,300, 400, series
your service tag tells you the full model number.
nor the OS (unstated)
XP, VISTA, W7 or W8?
this is what was used for the full series of production runs.
and they are NOT THE SAME.
tell what BACKLIT means. LEDs dead but at least name ONE>?
Please tell the helper this.
what OS first.?
tell exactly what Backlits (lights) fail, name them.
caps lock or ? what? give examples of what fails and what you are attempting to do..
on my newer HP, there are no keyboard lamps at all
not one but the HP has back panel that glows for that.
but needs the HP software loaded to make that work
only HP software works on that feature, period.
what operating system is this.?
the CQ57-400 is the last series is this it. why must i guess?
support for it is limited to this.
ill guess 400 for you as 1 example
then ill guess w7 32b
then you see this and load all these driver.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq57-400-notebook-pc-series/5186820
now il guess 100
here
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq57-100-notebook-pc-series/5059083
looks like last one made was 2012 (Compaq ended in 2013 at HP)
so has support until 2022. at HP.com
load all your drivers for you PC on the HP page.
skip BIOS. (line)
the problem here is HP used 2 processors here.
Intel
and AMD
mixing drivers up is problematic. here.
takes skills to do this.
why not ask at HP do this is.
real HP forums.... BINGO?
https://h30434.www3.hp.com/
Aug 02, 2017 | Compaq Computers & Internet
How to do a Screenshot on a Compaq Presario CQ57 Keyboard?
1. Hold Shift key then press Print Screen.
2. Open Paint, Hold ctrl and press v.
3. Save it as per your requirements.
Thank you...
May 08, 2015 | HP Compaq Presario CQ57 Laptop
Compaq presario cq57 my screen turns purple
Hello there!
It could be one of these:
1) bad monitor video pixels array.
2) Bad Video Card (heating)
clean your fan, for heating!
Apr 20, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
I can't type on my keyboard
try usb keyboard, could be keyboard is damaged
Jan 24, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
The spacebar key has come off the keyboard on my compaq presario cq57. How do I put it back on please
Glue it with either Super Glue or apply Ados to both the key board side and the back side of the key and then press together after 5 minutes.
Jan 10, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq presario cq57 keyboard wont work
Hi ,
Yes it can , If you know what your doing , open the laptop up to expose the keyboard , then clean and dry the keys very well and put it back together , let me know what happens ,,,,,,Goodluck Roy
Oct 30, 2012 | HP Compaq Presario CQ57 Laptop AMD DC...
How do i toggle the mouse pointer on my compaq presario cq57?
Usually on the Presario models there is a very small button just about the mouse trackpad that will disable and enable the use of it. It's usually between the trackpad and the keyboard
Aug 02, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
How do I disable the wireless key on Compaq Presario CQ57 keyboard ?
We have several terminals with keyboards that are used by different people during the course of the day. We had a similar problem with the Caps Lock and Num Lock keys. Solution(s): Straighten out a paper clip and make a quarter inch hook at one end. Insert the hook under the offending key(s) and pop it up. You can easily replace the key should there ever be a need. No ham, no foul.
May 30, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
HP Compaq Presario CQ57 Laptop Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
