Question about Pelikan PL-697 Predator for PlayStation® 2
Controller does not connect to ps2
I changed batteries, unplugged and plugged sending unit after power off on console.
My ps2 wont turn on
check to see if the adapter is working and that it is plugged in properly. if it is, your cord connecting your motherboard to your ps2 might be unplugged. to do this you need to open your ps2 ENTIRLY and plug it back in.
Dec 10, 2009 | Sony PlayStation 2 (PS2) Console
How do you change a paratonal control on ps2
  • unplug the ps2, wait 72 hours or.. Power on the PS2
  • Press the Reset button
  • Inset an R-rated DVD and wait until the board comes up telling you that parental controll is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
also if your parents never set one the defualt codes are 1111 and 7444.
Nov 23, 2009 | Sony PlayStation 2 (PS2) Console
GHA "elite" controller shutsdown ps2 system
you jus need new batteries for guitar controller
Aug 05, 2008 | Sony PlayStation 2 (PS2) Console
Some buttons on controller not responding
Ask yourself a few questions: Is the PS2 overheated? Was it under any physical contact? Try plugging the PS2 in a different power outlet, then try taking out all controllers and plug one controller in the second player controller spot.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
Controller port 1
I had the same problem once, although with controller port 2. What had happened with me is someone had jammed the controller into the port too hard and actually jarred the board inside loose. When I would plug in the controller, it fit ok but wasn't making a good connection inside the machine. This could also be caused by repeat plugging/unplugging or if a controller was pulled out by someone tripping over a cable or something. I wouldn't recommend opening the system yourself as it will void your warranty, but if this is the issue, it is very easy to fix. Another possible problem is just a bad controller, try another controller if you have one, if not, plug your current one into port 2.
Aug 21, 2007 | Sony PlayStation 2 (PS2) Console
PS2 console
has it un plugged or ripped
Jun 14, 2007 | Sony PlayStation 2 (PS2) Console
Pelican Predator 697 problem...
Pelican Products are unlicensed by Sony and would also void any warranty you had on the PS2. (Me not being a Employee,just what they'd tell you) Have you tried turning off the console taking out the Batteries of the controller,Unplugging the controller from the ports and replugging it back in? Also try a Dual Shock 2 Analog controller (If you have yours still) and see if your ports have gone bad. Usually 3rd party controls could potentially damage your PS2's Controller port as they do not supply the correct power or Data for your system.
May 24, 2007 | Sony PlayStation 2 (PS2) Console
PS2
If you have a wireless controller change the batteries and if you have a normal controller blow out the plug or call Sony.
Jan 03, 2007 | Sony PlayStation 2 (PS2) Console
Pelikan PL-697 Predator for PlayStation® 2  Logo
35 people viewed this question
Top Pelikan Video Game Consoles & Games Experts
James Wishart
Are you a Pelikan Video Game Console and Game Expert? Answer questions, earn points and help others
