Question about LG Heating & Cooling
LG model TS-K2430HL, heat pump, Outside fan stops after running for onl about 6 min.
When in heat mode my, LG model TS-K2430HL, outside fan stos running after only aprox 6 min. The compressor stops a few min later, as well as the inside fan . the defrost light comes on. If left alone the unit will start again but it may be hours later. It will do the same thing again. I can turn unit off and restart after a few min, but it does same thing, what woul be the cause
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
watugot
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
hotuna
  • 288 Answers
SOURCE: ruud heat pump outside fan
You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
Posted on Mar 15, 2008
dogcatstiger
  • 5 Answers
SOURCE: Goodman compressor cuts off when temp too high
When the condenser coil is dirty come high pressure and cut out the compressor, you can wash with the garden hose around the condenser coil before disconect the unit for prevent any electrocution or the sistem is overcharged
Posted on Aug 07, 2008
  • 124 Answers
SOURCE: High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Posted on Oct 26, 2008
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
My Goodman gsh103301ab. The fan in the outside unit will not come on. The heat is still coming out the the vents but, just don't think that sounds right. Is this suppose to happen?
If it's in cool mode, the outside fan definitely should run to remove the heat. If it's heat mode the outside fan will start only when pressure build up. If it's problem with condenser fan definitely the breaker or fuse will be blown when the amphs increased.
Dec 08, 2010 | Goodman CKL36AR36 Air Conditioner
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Jul 17, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Rheem Heat Pump outside fan seems to be running 24 hours per day. Outside temp 23 degrees. Is this normal? Model #RPKA-018JAZ
no this is not normal. the fan should stop running when the thermostat is satisfied or when the heat pump goes into defrost mode. if it is running nonstop, there is a contactor that operates the fan and compressor that if it sticks will get line voltage to it. you would have to take the cover off of the outside unit and turn the thermostat to off. If the fan continues to run, you need a new contactor.
Jan 13, 2010 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heat pump fan does not run when house heat is on
The outside fan should be running except when the Heatpump goes in to defrost mode. Then the fan stops with the compressor running and it switches the reversing valve to heat up the outdoor coil. That should last about 5 min and you may see steam come off of the outdoor coil. That's normal.
Is the compressor running? It's possible that it's stuck in defrost or the fan simply died. I hope this helps.
Feb 19, 2009 | Sharp CV-P09FX Air Conditioner
Compressor fan not running
Does it look like the coils are frosting over? Is it steaming? Keep watching, after about 30 min does the fan come back on?
If yes to any/all the above then the unit is probably in defrost mode and yes the fan will stop blowing during that time, but restart when the unit goes back into regular heat mode.
During this time you will likely notice warmer heat from the vents than normal and the "AUX or EM HEAT" light will be on.
That is your backup heat system. It should automatically come on during a defrost cycle.
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Heat Pump Reset Button
If running in heat check indoor air filter if in cool wash out outside coil with garden hose make sure fan is not overheating and shutting down.
Jan 06, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
