Question about Dr. Infared heater 1500W Elite Series Infrared Heater with Humidifier and Oscillation Fan
After pushing mode button unit shut off and will not restart
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
I just sent u an email about my danby showing a P2 sorry it was a P1.
P1- means the dehumidifier is in a defrost mode. This occurs when the temperature on the evaporator gets too cold and the unit shuts down to defrost (a defrost cycle).
P2- means the internal bucket is full of water.
Hope this helps!
Jan 25, 2014 | Danby Humidifiers
We just bought an idylis ultrasonic humidifier, but the directions don't make sense. It says to push the button in and wait til it pops out to set the humidity level. It nevers pops out by itself.
I am very fond of my Idylis humidifiers. Best I've ever had. When I bought a 2nd one, I noticed that the HUMIDITY SETTING button had a small sticker on it that said "PUSH TO ROTATE". My larger unit [no longer available] did not have the sticker. And, the sticker instructions are indeed confusing. The button actually has 2 positions 1) when depressed all the way in the settings are locked in place and 2) when pressed in just enough to pop the button up and outward, the button becomes a rotating column that can be turned either L or R to set the desired % humidity. Once the digital readout is at your preference, push the column/button in to lock it down and secure your setting. OMG, so wordy on my part! I think the darn "PUSH TO ROTATE" sticker is not helpful.
Jan 27, 2013 | Humidifiers
I have the unit listed below and I have an amber button on the unit that keeps on flashing (reset button). I've try to push the button in and reset it but nothing happens... The unit also dos not have any...
Not having any water in the reservoir is more than likely the problem. Has someone turned off the water supply line valve to the humidifier? Does the inline, water sediment filter need cleaning or replacing? The real question is, why did the water supply to the humidifier stop? Troubleshoot that problem based on the questions asked above and you'll solve the problem.
Hope this helped you solve the problem.
Mar 10, 2011 | Honeywell HM509H8908 Humidifier
Aprilaire 700 humidifier does not come on
Make sure the fan unit door (over the water panel) is closed. Push on it to ensure it is fully shut.
Feb 16, 2010 | Aprilaire 700 Humidifier
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Dr. Infared heater 1500W Elite Series Infrared Heater with Humidifier and Oscillation Fan Logo
26 people viewed this question
Top Dr. Infared heater Humidifiers Experts
Mack Baxter
Dennis
Are you a Dr. Infared heater Humidifier Expert? Answer questions, earn points and help others
