Question about Nextbook Tablets & eReaders
Reseting tablet. Problem is that the tablet is constantly reseting, and was told that it is a faulty folder. What should I do?
Acer iconia tablet is constantly reseting, I have done hard reset and now it resets even faster, before system is fully loaded. What should I do?
Sounds like a system crash. Uninstall any recent apps which may be causing it, or if that fails, do a factory reset, not just a hard-reset.
Feb 11, 2017 | Acer Tablets & eReaders
My max West tablet 7 inch 7180 K turned off on its own at 74 percent battery and it will not turn back on no matter what I try and the red light does not come on whenever I put it on the charger.I was told...
There is probably a loose battery wire or software issue. If you can, remove the back and check for a loose wire and borrow a soldering iron from someone to fix it yourself. If it is software there is nothing you can do without turning it on and factory reseting or just press the reset button (if there is one)
Mar 06, 2015 | Tablets & eReaders
How can my tablet read the sd card again?
reset it without the sd card installed.
also...if you have a card reader on your computer....put the sd card in it and see if there is anything on the card. You may have deleted everything on the card by reseting your tablet with the card in it.
Mar 02, 2015 | Samsung Galaxy Tab 2 GT-P5113 10.1" 16GB...
Icloud login after account locked out for security reasons
Try this:
If you can't remember them your codes; then go to Express Lane and select 'iTunes' from the list of 'products' in the middle of the screen.
Then select 'iTunes Store', and on the next screen select 'Account Management'
Next choose 'iTunes Store Account Security' and fill in that you'd like your security questions/answers reset.
You should get an email reply within about 24 hours (and check your Spam folder as well as your Inbox) - but some recent posts are saying that Apple have temporarily suspended the reseting of security question/answers whilst account security processes are improved, so it may take longer.
I hope this helps. I use Outlook notes to keep track of my passwords; I have SO many!
Jan 23, 2015 | Apple iPad 32 GB 3G Tablet PC
Son forgot passcode for tablet
One opiton you have is to overwrite the current setup on the tablet. The download for the firmware file can be found at Proscan site here: http://www.curtisint.com/html/custservice/manuals/PRO_PLT7223G_FIRMWARE.ZIP Unzip the files on your computer and extract the contents to your desktop. Now, use the micro usb cable that came with your tablet and connect one end on your tablet first, leave the computer end open for now. Find the small pinhole next to your tablet`s usb port and use a small pin to press it, while plugging the cable to your computer. Your PC should now say finding a new USB device. From the list, select iRockusbDriver from the folder to install the driver. From here, run the RKbatchTookl.exe file that was extracted. On the choose file path screen, select Update.img and click on Upgrade. The process should only take a few minutes and your tablet will be reset when done.
Mar 20, 2014 | Proscan 7-Inch Android Internet Tablet,...
My nobis pc tablet wont get past the second loading screen
Do a hard reset. Hold the power button down for twenty seconds. This is a hard reset if this does not solve the problem I recommend returning it as this is more than likely a manufacturer issue
Jan 24, 2014 | Tablets & eReaders
Wifi wont stay on
Avoid resetting to often your tablet. This makes the system worse. May be you are running to many operations at the same time the tablet cannot handle. I advise you close the task before you start a new one.
Jul 19, 2013 | E FUN Android Tablet Next7p12
Reseting my IPAD
Hi There,
You have to enter DFU Mode (iPad LCD will be black) before restore, and
please follow this step by step to enter DFU Mode:
  • Attach the phone to the pc
  • Turn the iPad off
  • Hold power and home together for *exactly* 10 seconds
  • Release power but keep holding home until the pc beeps as a USB device is recognized.
  • At no point will the display come on. Now your restore should work.
regards,
dm
Jul 23, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
18 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Beej West
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
