Question about Emeril from T-Fal Emeril Lagasse Electric Pressure Cooker
Steam is escaping
When I turn on the pressure cooker steam escape s from the valve
    New Friend:
  • 190 Answers
The valve should be seat to sealing. When the cooker is coming up to pressure it is normal for the steam to push oxygen out of the valve. Then, once it has reached pressure and the cooker starts to count down the cooking time the steam will stop coming out.
http://www.hippressurecooking.com/recent-forum-posts/
Posted on Feb 19, 2014
Steam is escaping from my pressure cooker
normal if from the pressure relief valve
Apr 23, 2018 | Crock Pots & Slow Cookers
I bought this pressure cooker and there was no manual in the box
Pressure cookers these days are pretty much foolproof. You generally use a small amount of water in the cooker, put in the food to be cooked, attach the lid firmly, turn up the heat until steam escapes the pressure valve, reduce heat so a small amount escapes, cook until done. Cooking time is greatly reduced in a pressure cooker because the vapor pressure above the water makes the water boil at a temperature higher than the usual 212 degrees Fahrenheit .
You can do an internet search for pressure cookers in general, or yours in particular. You didn't mention if yours is stove top or plug-in. You should search for the type yours is.
Jul 17, 2017 | The Kitchen Appliances - Others
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
How often do I need to change the rubber gasket on my pressure cooker?
That really depends on how often you use your pressure cooker and what kind of foods you cook in it. You might start to notice steam escaping between the lid and the pan after a while. You can try stretching the rubber and making sure it's sealed properly and cleaning the valve etc. If after you've done all that it still is leaking steam, it's a sign you probably need a new rubber gasket.
Feb 14, 2013 | Home
Why is there steam pouring out of my pressure cooker when I start to cook a piece of meat? Is that a sign that something is wrong?
Don't worry - it's a sign that your pressure cooker is doing what it's supposed to do. When you first start cooking the pressure is too low to activate the red center which is the overpressure valve. The steam coming out is just a way of getting rid of any cold air that's inside the pressure cooker. If the steam continues to escape later on in the cooking process then you need to check that your overpressure valve is clean and that the red center button is in the correct place.
Feb 14, 2013 | Home
Steam is escaping from floating valve
It is supposed to. If steam did not escape it would explode
Apr 21, 2012 | Wolfgang Puck Electric Pressure Cooker...
Steam is coming out from the floating lock pin but the timer is counting down. should steam be escaping while cooking under pressure?
Yes, otherwise the cooker would blow up from the pressure. This was a common problem with pressure cookers used on a stove from many years ago. Hope this helps!
Sep 26, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Steam escapes from pressure cooker
the gaskets are junk , i had to toss one myself i used one time then stored for a year and the gasket went bad , mine came from hsn when i called them ,there where no parts made for it . so out it went cheep china junk . sorry , good luck
Jan 14, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Emeril from T-Fal Emeril Lagasse Electric Pressure Cooker Logo
155 people viewed this question
Top Emeril from T-Fal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Emeril from T-Fal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
