Question about Singer Sewing Machines
Singer 4423 won't make buttonholes
With the button hole attachment (a long foot) attached, the machine only sews backward or doesn't travel at all.
helale
  • 3 Answers
SOURCE: One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
Posted on Oct 28, 2008
SOURCE: Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
Posted on Dec 02, 2008
SOURCE: machine beeps and won't sew when buttonhole
I just figured out how to use the buttonhole feature today. Make sure where you insert the button is towards the back of the machine. Pull down the button hole lever and make sure it's between to two plastic notches. The buttonhole lever will actually be pressed against notch B as described in the instructions. Insert your material and let the bottonhole foot down. You will to play with the stitch width and length to get the right size opening. I hope this helps!
Posted on Jan 12, 2010
  • 1116 Answers
SOURCE: I lost the manuel to my Singer Simple sewing
You can download a free manual at singerco.com
Posted on Mar 04, 2010
  • 1116 Answers
SOURCE: I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
Posted on Mar 07, 2010
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
My 4423 will not advance when I have all the settings set to sew a simple buttonhole. Why?
do you have a manual?
do you have the buttonhole lever pulled down?
if these suggestions don't help then the machine needs to be checked at a sewing machine shop
May 26, 2012 | Singer 4423 Sewing Machine
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
My singer 4423 will not make a buttonhole
you will be needing help from the service manual of your machine. The problem of buttonhole and how to solve it is discussed on page 28 of the service manual.
Click here: http://www.promanuals.com/serviceparts/singer-4421-4423-sewing-machine-service-manual/
Regards.
Sep 18, 2011 | Singer 4423 Sewing Machine
Trying button hole attachment- installed properly I think - when I push on presser foot an alarm goes off and it will not sew
Hi Dot,
1. Make sure you pull the buttonhole lever down- left back of your machine.
2. Select the button hole icon, or select the corresponding number for a button hole-very important.
Good Luck
Sep 07, 2011 | Singer 7426 Mechanical Sewing Machine
Machine beeps three times when buttonhole foot is on and pedal depressed. will not sew buttonhole. i have followed the directions in the manual for attaching presser foot and inserting button
does your manual mention anything about a buttonhole lever that must be pulled down each time you make a buttonhole & then pushed back up afterwards
Aug 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
I an having trouble making button holes. The
Make sure the plug from the buttonhole foot is going all the way in when you insert it. If that doesnt correct it, then the foot may be bad.
May 23, 2010 | Husqvarna Viking 1
Machine beeps and won't sew when buttonhole foot is attached - I have followed directions very carefully
Dec 12, 2009 | Singer 7462 Mechanical Sewing Machine
I get a beeping sound when I try to make button holes
Ensure that your buttonhole foot is attached, and that your buttonhole guide is slid all the way down(It is a small, flat-tabbed bar just behind your needle threader.)
Ensure that once the bar is down, that it is able to sit between the two buttonhole foot guide tabs, and is not pushed by either of the tabs in either direction yet.(The pushing of the buttonhole guide bar is what causes the machine to stop, sew sideways, and start going the other way)
Nov 30, 2009 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
