Question about Fuji Electronics - Others
Turn on keyring - Fuji Electronics - Others
HOW TO SWITCH OFF ALARM
Put key in ignition and turn on
Get a remote lock/unlock/alarm for your keyring
Sep 28, 2015 | Cars & Trucks
Key goes in switch but will not turn on 2002 jeep grand Cherokee
the lock has failed end of story ,problem caused by having a big bunch of keys hanging on the same keyring
Mar 02, 2015 | 2002 Jeep Grand Cherokee
Dinging bell on dodge caravan wont turn off even if key is removed lights out and door closed.
Check for play in ignition switch.If too much weight on keyring ignition switch may become damaged allowing key to be removed when switch is not actually fully in "off" position.
Oct 21, 2014 | 2000 Jeep Grand Cherokee
Compustar problems
bypass module
Jan 02, 2014 | Cars & Trucks
I bought a dream cheeky usb lcd photo keyring but when i plug it in the computer doesn't know it is there
your missing the drivers for your usb plug it in and go to device manager and see if there is an unknown device click it and do windows driver update
Mar 20, 2012 | Computers & Internet
Just bought a Zipp DP605 digital photo keyring and the software isnt recognised on my laptop. We have wwindows Vista.. please help, this is a xmas gift and i want to put photos on!
Dec 23, 2010 | Cameras
Turns over wont start theifed light blinking ran fine nite before did start for a couple of seconds about three times and thats about it keeped turning over till battery died
Either the little "chip" has fallen out of your key (usually in the end of the key next to where the keyring hole is) or the transponder on the ignition lock cylinder has failed.
Nov 08, 2009 | 1998 Ford Expedition
Photo key chain
Connect to pc. Press 'on' button on keyring. Change from 'charge' to 'update', then press > button. Photoviewer will then load. Good Luck!
Jan 27, 2008 | Tao Spectare digital picture Remote...
Help
It may be that the battery is bad, or the supply wire to the battery has broken or come loose.
What I suggested to someone else was to buy a memory stick, they are cheap and will hold many more items than the digital keyring, and they are quite small now too.
Jan 02, 2008 | Cameras
Electronics - Others Logo
26 people viewed this question
Top Fuji Electronics - Others Experts
Are you a Fuji Electronics - Other Expert? Answer questions, earn points and help others
