Question about LG 47LD520 47 in. HD-Ready LCD TV
LG 47LD520 wont stay on
The last few weeks tv wont stay on on and off like crazy when watching anything on xbox , i do not have cable so this is the only way i been doing it for months, i figured it was the hdmi cable so i bought a new one that did no good. i then hooked up old av cables it did nothing kept turning off and on, then last night my remote said simplink when i tried to use it and a simplink menu came up yet i have NEVER used this before and NONE of the buttons would work. now i have a psychotic brother in law who wants me to move out coul hehave done something to my tv to cause this? i called lg they wont helpme due to no more warrnarty. i cant reset anything as i have a LOCK on my settings and this remote wont work! PELAASE HELP
  • Krissy Bruce-Slawinski
    Krissy Bruce-Slawinski Feb 10, 2014
    i DO NOT HAVE CABLE!
    i got the remote working now and went to menu options like the tech told me to do to disable the simplink and there is NOthing there for simplink..wth?? how are these idiots controlling my tv? i know they are because it works fine til they get home. i didnt even think this tv was internet capable
2 Suggested Answers
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
Hooked up Xbox 360 last week, now can't watch movies.
turn off parental controls on x box and tv if they are avalible on your tv. then you can watch any movie you want. go to menu then system set and you should see parental controls there. hope this helps
Jan 25, 2013 | Philips Televison & Video
My lg42lg30 tv wont turn off and the meno icons are going crazy cannot control it
Sounds like you have a main board issue. But if you can post a picture that would help confirm if it is the main Board. please respond to this same post for assistance.
Jan 03, 2013 | LG Televison & Video
How to identify what is wrong with my LG 47LD520 HDTV that suddenly turned off.
If you have sound knoledge in digital electronics, download the service manual to your tV from net and try to find out.
May 02, 2012 | LG 47LD520 47 in. HD-Ready LCD TV
What setting & channel does LDD 47Ld520 TV need to be on to watch a DVD?
Depends on how its hooked in how did you hook it up and on what conection?
Jan 12, 2012 | LG 47LD520 47 in. HD-Ready LCD TV
My tv hdmi ports connedts to only lg products now i was able to connect my playstation to my lg tv and watch 3d movies but last couple days tv says connecting and no signal playstation works with hdmi...
Dirty Connections Dust plays Havok with those connectors go to Radio Shack and pick up a Can of Contact Cleaner Spay both the Jacks and The cables
Dec 30, 2011 | LG 55 55LW5600 3D LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Why will my VCR not work with my LG LCD TV,model 47LD520?IT comes on but will not play tape.
The tv LCD screen panel reconize the VCR and have the LCD screen panel,have a LCD have a blue screen wright,that incated u hook up the VCR wright.The VCR is not playing the tape,because is the VCR have problems,Not the tv itself.
Oct 26, 2010 | LG 47LD520 47 in. HD-Ready LCD TV
Blue light shows up and blinks when I power it on....But the screen stays black. No sound no nothing. Just bought this tv yesterday!
This tv have problems,the tv Tuner signal board, that the board,that take in the incomming broadcasting signal cable.This board,it dead.Call LG for the warrenty replacement of this board.
Oct 18, 2010 | LG 47LD520 47 in. HD-Ready LCD TV
LG picture quality
not true about the 200 hour thing, and the pic qualith can be a couple of things, if you have a cable box, it can be caused by a week signal, or a loose connection, if the cable is just going from the wall to the tv, you may want to reprogram the chanels
Jan 09, 2009 | Televison & Video
LG 47LD520 47 in. HD-Ready LCD TV Logo
64 people viewed this question
Computer Repairing
Computer Repairing
