Question about LG Televison & Video
Simplink and remote help
I have lg 47LD520 the last few weeks it wont stay on while watching tv on my xbox or movies. i bought a new hdmi cable as i thought that was issue, last night it didnt work worse then ever off and on like crazy, then i got a simplink menu when i pressed anything on the remote control , and now my remote wont do anything and my tv wont stay on lg wont help as its past the year warranty i am VERY upset as i have BARELY watched this POS HELP ME
  • 8 Answers
SOURCE: Channels change by themselves after 20-30 minutes of tv being on
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
Posted on Jun 17, 2008
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
  • 211 Answers
SOURCE: 37LC7D LG LCD tv turn's on but remote keys and tv side keys unresponsive.
HI,
I'll think your power supply is down.
Maybe there's still garanty on your TV.
kind regards,
Gerard
Posted on Oct 23, 2008
  • 149 Answers
SOURCE: playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Posted on Nov 13, 2008
SOURCE: LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
Posted on Dec 11, 2010
My tv hdmi ports connedts to only lg products now i was able to connect my playstation to my lg tv and watch 3d movies but last couple days tv says connecting and no signal playstation works with hdmi...
Dirty Connections Dust plays Havok with those connectors go to Radio Shack and pick up a Can of Contact Cleaner Spay both the Jacks and The cables
Dec 30, 2011 | LG 55 55LW5600 3D LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
While I am watch a movie a message keeps popping up that says "Simplink please try again"
if you go into the setup on the t.v. and the options menu, you can turn the "simplink" off ...
Apr 27, 2010 | Audio Players & Recorders
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Televison & Video Logo
13 people viewed this question
Computer Repairing
Computer Repairing
