Question about Garden
Throttle cable has unattached from trigger
Throttle cable has come off trigger
    New Friend:
  • 30 Answers
Unfortunatley there no other way to do this but you are going to have to split the case in half to get to it, My suggestion is take chain and roller off first it makes it easyier to handle, hen large dirty rag work your way round taking all screws out slowly take cae cover off, PS before you start drain petrol off store it somewhere else in a petrol can it makes it all lighter when case is split you can see trigger and cable catch unit hopefully plastic bit hasnt snapped that holds it in place if you can grab with plyers pull it back into position make sure it works ok before you put everthing back, and while you have it split in half give it a good clean at the same time and lubricate it all especially the cable onto carb bit it will operate better, hope this helps
Posted on Feb 18, 2014
Attaching cable to carburettor on MH542 trimmer
No problem Graham Finch...
We do not MAKE phone calls...
The throttle wire (From the trigger) seems to
be even cruder than a bicycle brake cable.
McCulloch Cable (
bicycle type)
genuine McCulloch 213919 cable throttle trigger Mac 60 70 80 95 trimmer...
By looking
at the pictures on eBay you
can see how simple the interfaces...
(triggers and wires are listed (fairly cheap here (USA)...
WIRE Type:
It appears the sheath is merely CRIMPED to
the trigger plate and the wire is only passes
through the TRIGGER HOLE (top wire only
the bottom is not connected... as shown))
SEE PICTUREs
NOS OEM McCulloch Trimmer Throttle Cable 91984 eBay
Try searching for your trimmer dealer in the UK
(I think the postage from the USA is prohibitive).
Happy hunting.. Hope this helps.
Carnac the Magnificent
Oct 24, 2017 | McCulloch Garden
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
How do I connect throttle cable to throttle trigger?
Search for online manual, that has the diagram, showing the location the end of throttle cable at the trigger. You will have to take apart the handle assembly, to access the cable and trigger.
Nov 05, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
When I try to lower engine rpm by retarding the throttle control to idle the engine speed does not change?
Your throttle cable is screwed up , you can probably fix it without buying anything. It probably just came unattached
Jul 02, 2015 | Kohler Cub Cadet LGT 1054 54" 26HP Lawn...
How much does a trimmer throttle cable cost?
A trimmer throttle cable can cost anywhere from $10-$25.
Jul 15, 2012 | Stihl Trimmer Throttle Cable Km 40 50 56...
Spear and jackson, sht26X, the throttle won't
I suggest taking the handle apart to see if anthing is blocking the action of the trigger from inside, like some debris. Then see if the throttle cable moves if you pull it. If necessary keep tracking it back to the carburetor, maybe there is a piece of debris in there blocking the throttle lever on the carburetor.
Sep 16, 2011 | Garden
How do i put the throttle trigger back on stihl fs45
On the carburetor hold the throttle lever to where it would be at full throttle. Then you can put the cable back in the catch for the cable that is on the throttle lever and let go of the throttle lever. The throttle cable should work with the throttle trigger now. The throttle cable only fits one way. The larger hole on the throttle cable catch should go to the ball at the end of the cable.
I hope this helps.
If you feel you cannot do this, then I would take it into your closest Stihl dealer and ask them if they would help you. I do this small repair for free at my shop. Have a good day.
Apr 04, 2011 | Garden
Stihl HS 74 gas trigger does not move at the carbeurator
The cable has broken or become unattached at one end or the other
Sep 28, 2010 | Garden
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and...
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Jul 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Model P3314 throttle is stuck
Remove the air cleaner assembly to see the carburetor throttle mechanism and open the handle so that you can access the throttle trigger. There should be either a cable or wire connecting the trigger to the throttle arm on the carburetor. Try moving the trigger and see if it responds at the carburetor. Is the carburetor arm against the idle stop screw, wide open, or some where in between? There should be a spring at the throttle arm that returns the arm to the idle stop if the cable/wire is disconnected. The trigger mechanism may be jammed with sawdust to prevent movement. Hope this helps!
Mar 19, 2010 | Poulan Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
