Question about Del-Rain 1500-V 1500 Watt Ceramic Heater
Del rain operation manual - Del-Rain 1500-V 1500 Watt Ceramic Heater
Is Del-Rain still in business?
Del-Rain Corporation
4808 Tomson Avenue
Niagara Falls, NY 14304
Phone: (716) 283-0060
Call in the morning and see if anybody answers.
Jan 26, 2017 | Computers & Internet
Need to find out how to operate them. Is there a manual I can look at on line?
Manual - Rain Bird
www.rainbird.com > Homeowners
Rain BirdHave a question? Looking for a manual or troubleshooting guide? Enter your query in the search box below to find helpful resources on the Rain Bird website.
Sep 24, 2015 | Garden
Does anybody out there have an owner's manual for Lifetime Furnace Model # 1500 VI by Del Rain?? PLEASE contact me!
I have used one of these for years and was looking to find a new one and came across your question. I don't have the manual but here is how the programming works:
On/Off (obvious)
Heat/Fan (if lit it makes heat if off it just runs fan)
Auto/Manual (if off the temperature slider causes the fan to run on high or low)
Preset on (I don't use this but probably can be used to set it to turn on after a selected number of hours)
Preset off (if lit the heater will turn itself off after the number of hours shown on the right)
Time select (press this button to change the number of lights shown vertically ... each is labelled and you add them up to get the hours you want from 1 to 15 ... so if bottom two numbers are lit (1+2) then heater will run for 3 hours then turn off)
Feb 17, 2012 | Del-Rain 1500-V 1500 Watt Ceramic Heater
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
Del-rain model lt-101 does not blow hot air only cool air!!
most likley the high limit,you can check with ohm meter,or simply short it out,but thats a fire hazard.if element is burned out is junk.again check with ohm meter.
Dec 22, 2010 | Del-Rain LT-101A 1500Watt Ceramic Heater
When I turn it on it beeps constantly. It has been sitting idol for a few years. Need a manual too.
Check to be sure that it is sitting level to start with.
Second, unplug it. Blow it out with the hair dryer. Look for any breakage in the cord.
Nov 07, 2010 | Del-Rain 1500-V 1500 Watt Ceramic Heater
My automatice wiper won't turn off on thier own
It has auto wiper control. Yank your wiper stick 1 notch down. The windshield should be free of rain droplets or else it would think it is still raining and operate it in auto mode. In auto mode it will shut off when it doesn't sense rain droplets on the windshield or removing the key from the ignition. Once it is off, it can only operate in auto mode by moving the lever 1 notch up while raining. Yours must be in the 1st speed manual selected position of the lever. Every time the ignition is switched on the wiper operates regardless until key is removed from the switch.
Nov 23, 2009 | 2000 Volkswagen Golf
Del-Rain 1500V ceramic heater switch.
is it a little rocker switch ? if so any local hardware store, like HD, or Lowes, or any appliance wholesaler will carry these switches, or try online to the manufacture, hope that helps
Jan 20, 2009 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Heater smells like it got too hot!
check for dust in the air path through the heater. the fan forces air through the element.  if you have an air blower - blow air in a reverse direction through it.
Oct 15, 2007 | Del-Rain 1500-V 1500 Watt Ceramic Heater
DEL-RAIN 1500W MOVABLE HEATER
can you read resistance across the ceramic element?
Sep 11, 2007 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Del-Rain 1500-V 1500 Watt Ceramic Heater Logo
108 people viewed this question
Top Del-Rain Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
Are you a Del-Rain Heating and Cooling Expert? Answer questions, earn points and help others
