Question about Makita 9227c Polisher Electronic Variable Speed
Replace power cord 9227c
Need info on how to disassemble handle to replace power cord
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
Makita 7" 9227c I
the part number is 224517-1 and you should be able to find it at any hardware store that sells Makita tools or you can buy it online from "makitausa.com" they also have a service center locator that you can use to buy it locally. Let me know if you need more assistance.
Jun 17, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
Hi ! My unit do not turn to its right rpm, erratic power.
could be a couple things. UNPLUG tool and remove one handle half and see if it is jammed up with lambswool from the bonnet. It can get under the brushes causing the erratic power. If thoroughly clean the entire motor housing and then remove and check the brushes for wear. Let me know if you need more assistance.
May 26, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
How do you disassemble the handle to replace the power cord. I've removed the handle from the body of the vacuum, but don't want to break any plastic covers trying to pry them off to access the power cord...
bad news to you.(don't get mad at me please). 2 prong means is a "DOUBLE INSULATED" vacuum. any electrical repairs are not recommendable other by a shop because after repairs they have to test for grounding with a special meter to prevent electirical shocks. for that reason I personally can not give advice on how to do it. if you want to take the risk, well.... good luck to you. I do this for your safety and ours. I hope you understand my position.
Feb 09, 2011 | Hoover Platinum Collection Upright Vacuum
Cord wrapped around unit while polishing and shut down. cannot restart
possibly ripped the wires from switch or broke the wires in the cord itself. You can go to Makitatools.com for a breakdown on this tool, but would have to guess at the above.
Aug 31, 2010 | Makita 7" 9227c Buffer Polisher Sander Kit...
I need to replace the cord on an older Hoover upright, model S660, about 1986 vintage. The cord broke where it enters handle. Handle comes apart easily. Just not sure how to pop the switch out without...
check ebay. those vacuums are worth fixing. I loved them. they would **** the carpet off of the floor! those cords aren't hard to replace.just remember the way you got the old one out.
Aug 12, 2010 | Vacuums
I need to replace the power cord. I have a new
The cord goes into a water-sealed unit on the drive motor internal to your aquabot, so the unit has to be partially disassembed to gain access to the drive motor. The one thing you probably do not have, which you will need to do the job, is the waterproof sealing putty which your supplier can send to you at a small cost. If you happen to be near Phoenix AZ I can help you put on the new cord, and this website gives plenty of info, too: httpp://www.i-love-my-aquabot-automatic-pool-cleaner.com/ S Christian dansker01@#msn.com
Jul 15, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
A makita 9227C does not work
Hi, Unfortunately there is no external test, It has to be opened and troubleshot with a multimeter. Especially something with a variable speed controller, power cord, brushes, switches, ect. It could be several things. If you are technical enough to take it apart let us know we will try to help. Good Luck to you!
Feb 20, 2009 | Makita 7" Electronic Sander - Polisher...
Makita 9227c stall
Hi hope to help
Have you tried this unplug the machine! then cut the cable about 6" from the machine then strip the machine and rewire the long length of cable back to the switch. The 6" that has been cut from the machine discard it.
The problem i used to get is where the cable is clamped in the handle the wire inside the insulation cracks so that when the machine is in one position is ok but then when is moved it goes off again.
It also could be the field coil (part of the motor) if it gets hot then cuts out the field could be braking down!!!
hope this helps.
Feb 29, 2008 | Makita 7" Electronic Sander - Polisher...
Makita 9227c Polisher Electronic Variable Speed Logo
37 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
