Question about Kenmore Dishwashers
I would like to add a cup of white vinegar at the start of the last rinse on my Kenmore Elite dishwasher, model no. 665.12779K311 in order to avoid white film forming on my dishes, due to the hard water. Could you please tell me how many minutes it takes for the last rinse to start, so I can pour the vinegar in at that time? my hard water.
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
SOURCE: white film on all the dishes and inside the dishwasher
I had the same problem. Only thing that worked for me was adding Glass Magic. No more white film for me.
Posted on Jul 23, 2008
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
tzweeb
  • 318 Answers
SOURCE: dishwasher dishes not clean
first of all to remove residues from your d/w...what will work to remove the scale and soap residues is called "d/w magic". it comes in a plastic square bottle and you can get it at any grocery store, lowes, or sears.
you just remove the cap, put in the top rack and run a full cycle with the water heat boost option and it will clean out almost any residue from your unit. if it is really bad you may need to repeat this 2 times.
then in the future use dry powder soap, not tablets, fill both cups only about half full, use the normal cycle with the water heat option. also make sure the rinse dispenser is full with jet dry or similar product. then you should not get the residues returning.
after you have tried this then you should brush off any food particles before putting the dishes into the unit. do not assume the d/w will "chop" up any food left on the dishes. they are designed to chop up soft food items, but they also will get plugged at the same time. so its best to just brush the dishes off first.
next is if you still have washing problems, then make sure the unit is filling up with enough water. after you start a cycle, let the unit run for about 2 minutes, open the door and see if the water is just below the level of the heating element. thats how much water they need to circulate properly.
i will reply back if you want to know more.
good luck tom
Posted on Dec 31, 2008
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
Tip
Dishwasher Cleaning
If you have hard water, you may experience stains on dishes and scale forming on your dishwasher heating element.
To clean it up and improve performance, there is a product called "Dishwasher Magic" that descales the machine.
Another trick, particularly if you can't find Dishwasher Magic, is to use white vinegar.
Run the machine empty with about two cups of white vinegar added to the bottom. Then run it again empty to remove the odor of the vinegar.
If you have dishes that have a built up film (you notice this particularly on clear glass) you can soak it in vinegar for ten minutes or so and then rinse it off with tap water. For stubborn stains you may want to rub with a paper towel.
The best way to avoid these problems is to use rinse agent in your dishwasher, and to use the Dishwasher Magic once every month.
UPDATE: A low cost alternative to this product is to simply use unsweetened kids soft drink mix....aka KoolAid. It's got lots of citric acid, just like the Dishwasher magic. To get similar results, you need to use two large packages or four to six of the small one quart size pouches. IMPORTANT: Don't put any sugar in it, just add the powder to the bottom of the dishwasher and run a cycle.
on Jan 01, 2010 | Dishwashers
I have a heavy white film on dishes after the cycle. It is mostly on the dishes on the top rack. I've had this dw for 3 years and it just started happening. i use cascade powder and i don't even fill...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Jan 26, 2011 | Kenmore 15639 Built-in Dishwasher
The dishwasher is working, but there is a soap like film left behind on the dishes, glasses and silverware. It's a Kenmore dishwasher.
Hi
Daniel
Jan 07, 2011 | Kenmore Dishwashers
The glasses come out looking cloudy. Why is that?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Hope this helps... Please post back if more information is required.
Daniel
Dec 19, 2010 | Kenmore Dishwashers
After washing it appears white on all the vessels. It started happening recently. how to fix it?
Hi
Daniel
Nov 27, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
I put regular dishwasher detergent in the dishwasher and now everytime the cycle run foam keeps coming out.
You are not the first to have this happen. Put some cooking oil (start with a quarter cup) and let it cycle. When the suds are mostly gone use a cup of white vinegar in the rinse cycle and you are good to go.
Eric
Jan 04, 2010 | Kenmore Dishwashers
Lots of stuff left on dishes and glasses real filmy
run unit through a clean cycle. turn on hot water at sink til it gets hot then shut off . then tuen ion dishwasher when it starts washing open door and add 2 cups of white distilled vinegar and let it go through a cycle ( no dishes) when done. turn on hot water at sink before you use dish. also fill both soap cups and use rinse aid or jet dry. you should see better improvements. hope this helps..
Sep 17, 2009 | Kenmore Dishwashers
Dishes not getting clean, white film
Hello cljjtm,
You will need to clean the wash arm and unclog the spray holes.. use white vinegar to break down the soap deposit and a sharp metal tool such as an awl to free these holes up from any build up.. white vinegar may be applied while unclogging the openings..
Then, once the spray arm holes are freed of deposits..Start with an empty dishwasher.. and then start a wash on the hottest available setting and then after a few minutes of it cycling.. pause it and add a cup or two of white vinegar to the wash ( the white vinegar should break down any soap residue and allow it to be rinsed away)..once complete.. use about 1/3 less detergent than you have been. See if that gets your DW back in working order.. Hope that helps..
Regards,
Rick
Feb 16, 2009 | Maytag 24 in. MDBH955AW Built-in...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
