Question about Dryers
Dbxr463eboww The dryer has power to it. When I put the dryer on any cycle and turn it on the dryer does not actually turn on. It just hums. It was working fine and just started to do this. Any idea how to fix this or what the problem could be?
  • Dryers Master
  • 8,220 Answers
Your glides are probably gone and the drum is riding on the plastic bearing that the glides mount to. Glides are easy to replace. I made a video:
Posted on Feb 09, 2014
  • 1462 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Posted on Mar 28, 2007
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
Master_Tech
  • 770 Answers
SOURCE: Maytag Perfoma model PYE2300AYW
Bad start winding in motor
Posted on Jan 31, 2008
  • 15 Answers
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Posted on Jul 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My dryer was running drying
Hi srmiller...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.Sometimes you have to use a flat bladed screwdriver to insert under the lid and pry up to remove the lid from the retaining clips.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 27, 2011
Testimonial: "This really helped me."
Dryer drum stops turning mid-cycle
The belt may be in need of replacement.
Dec 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
DRYER STARTS BY ITSELF
Bad timer. Replace the timer.
May 13, 2009 | Maytag PYE2300AY Electric Dryer
Dryer wont start, drum hard to turn-revised
get a new drumm it might be bent if your putting stuff that weight alot in your dryer if its making a skeeking rusing soung get a new drum about 400 dollers
Dec 21, 2008 | Dryers
HELP!!! Dryer will not work!!! MODEL#DBXR463EBOWW
check the door switch and the heater box main fuse,let me know-mike
Mar 22, 2008 | GE DBXR463EBWW Electric Dryer
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Feb 14, 2008 | Dryers
Dryer has power won't start cycle
Hi, check first the power outlet , if still does not turn and motor humming during starting time , test the capacitor with multi tester, disconnect two wire of capacitor if not reading replace capacitor .
Jan 20, 2008 | Kenmore Elite HE4 Electric Dryer
Clothes dryer
dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt. It will take care of your problem
When I try and start my ge dbb3300eaoww dryer it buzzes as if it wants to start if I spin it with my hand it will work. I put a new belt on it and it does the same thing.
Motor start switch is bad. This is typically replaceable with out replacing the motor.
Will take care of the problem.
My drum will sometimes stop turning in the middle of a cycle, and the motor just hums. I pause the dryer, open the door, rotate the drum, unplug and plug the electrical, and then it will usually complete the cycle. Does that mean the belt is "occasionally" slipping? How do I check this?
Replace the belt. It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time. This will take care of the problem.
Sep 15, 2007 | Dryers
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
