Question about Kenwood KVT-514 Car DVD Player
Reset button After battery was dead after sitting 3bdays in a patkimg lot, the unit shows no signs of life. I pulled and replaced the 15 amp fuse behind the unit, them pressed and held in the pinhole between the loudness button and the volume control. Still no signs of, life suggestions?
3 Suggested Answers
kenw392
  • 2226 Answers
SOURCE: The unit functions except for a dead display.
you may have a bad flexible cable that goes between the face and the main mother board.
Posted on Jan 18, 2010
kenw392
  • 2226 Answers
SOURCE: volume went extremely loud..had to hit reset
sounds like you may have a bad flexible cable. the cables generally last about a year or so on those decks, depending on how often the face flips around.
Posted on Jun 08, 2010
My 1997 kawasaki 400 pirarie will not show any sign of life when i turn the key like No lights to neatrul light nothing only thing that will work is my winch any suggestions?
Look for a fuse where the postive cable comes from the battery going to the starter relay - this fuse (like a 10 or 15 amp box fuse) allows all the electrical to basically go to the bike. When it blows - no ignition, but the bike will usually pull start. - Your winch is probably still working because usually - it's hooked up straight to your battery. if that's not it - let me know and I can help you troubleshoot it - all the best
Dec 27, 2015 | ATVs
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
There is a major drain, when the car sits for about two days, the battery is dead. My brother and I strarted pulling fuses and found that by removing fuse # 12 a 20 Amp for the auto level control and #15...
I would check the Fusible Links for corrosion
I had the same problem with an 86 Deville
I was checking out the level control,then watching
for relays to go to sleep
When I got the hang of it & I did have the shop manual &
wiring diagrams as I do for all my vehicle,I sort of accidently
found a fusible link almost gone from corrosion,then not
available from any car in the world,so an orange wire nut
had to do,not right but fixed it
I had the VOM in the battery cable on AMPS when pulling
fuses,interesting experiment,learn a lot in a hurry,just don't
open a door & wake up modules. In my case that was a
19 min waite to start over
Jul 02, 2011 | 1993 Cadillac DeVille
I have a 1992 Cadillac deVille and the battery discharges overnight. If I don't disconnect the battery, it will be dead in the morning. I checked all the fuses and number 14 and 15 show a 12 volt current...
Hello and welcome to FixYa!
If the battery light is on, I strongly suggest that you have the battery charged. It can be an indication of a weak battery or a faulty alternator. If the battery light still on after charging then the problem will surely be on the alternator itself. If that's the case the alternator should be replaced to resolve the problem.
If the battery won't hold charge even on a new alternator then the problem will be on the battery itself. It surely is in the end of it's service life and replacement will be necessary.
You may try to reset it to by removing the positive battery connector, letting it sit for at least 5mins. then reconnect it again. This will reset the system and can get the battery light off.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 16, 2011 | 1992 Cadillac Seville
The battery went dead in my 97 subaru legacy gt and was dead for a while. i relaced the battery and now the parking lights blink and when i start the car it wont idle it shuts off. does something need...
Under the dash to the left of where your left leg would sit is a box. 4" x 4". It is your security box. There is either a red button on it or a wire with a button. push the button for about 15 seconds and it will reset the security system. Good luck and have a great day.
Nov 07, 2010 | 1997 Subaru Legacy
Electrical Problem - dead battery
Sounds to me like you may need a new rectifier put in the alternator,a shorted diode in the alternator could be powering up things that should go dead with the key in the off position.To prove this,instead of pulling the fuse,take the plug out of the alternator and if all is well,you have your answer.
Jun 09, 2010 | 1998 GMC Sierra
The ups wont work when its on battery or on electricity and nothing happens when i press the (on) button it remains off
These units, while hot swappable, will NOT start with dead batteries connected.
You will have to replace the batteries to confirm if the unit is still usable. Sealed Lead Acid Batteries do have a shelf life when a charge is not applied and will fail after several months of sitting around.
If your unit was working fine before it was put in storage, I definitely would consider just replacing the batteries. It is possible that the batteries are connected loosely, you can try opening the unit up to double check all the connections but if it has been sitting for more than a couple months, I would definitely consider the batteries dead.
Apr 13, 2010 | Tripp Lite Lite OmniSmart 1000 PNP...
Smart2200RMXL2U shows no sign of life after storage
You can find replacement batteries here http://www.refurbups.com/Tripplite-SMART2200RMXL2U-Batteries
Apr 02, 2010 | Tripp Lite Smart Pro UPS System
Took lightbulb out to replace and microwave went dead. No power at all. is there a reset button?
open the cover theres a 10-15-or 20 amp ceramic special fuse in the unit, sold at most hardware stores get the right amp rating,its on the side of the fuse
Oct 01, 2009 | Goldstar MV-1501 Microwave Oven
I have a 2001 chevy blazer that has a short that causes the battery to go dead within 8 hours of sitting. If I pull the 50 amp "RAP" fuse & the 15 amp Radio fuse it will not drain the battery. What do...
BATTERY VOLTAGE CAN DRAIN THROUGH STARTER RELAY OR BAD DIODE IN THE ALTERNATOR.I WOULD REPLACE THE STARTER RELAY.I AM LOOKING AT A ELECTRICAL DIAGRAM.YOU HAVE A 40 AMP IGNITION FUSE THAT FEED THE STARTER RELAY.IF STARTER RELAY HAS A SHORT IN IT.IT COULD DRAIN THE BATTERY.
Sep 12, 2009 | 2001 Chevrolet Blazer
Kenwood KVT-514 Car DVD Player Logo
16 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
