Question about Health & Beauty
One bulb won't work on tanning bed
I have one bulb on top of tanning bed that won't work. I replaced bulbs and bulb holders and the one bulb won't come on. What could cause this?
SOURCE: tanning bed setup
HI a bought a tanning bed last night from a tanning salon it was hooked threw a phone line or something like that my hubby brought it home and hooked it up here .now i cant get it to work ,will i ever see it work and how can i get it to work for me.
Posted on May 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: night light won`t work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
SOURCE: Replace headlight bulb on 2001 330i
1) Pinch the socket connector to release the 2 pin connector
2) Turn the Gray mounting bracket 1/8 turn CCW –it will come loose
3) Replace bulb – don’t touch new bulb with hand
4) Insert Grey mounting bracket and lock with 1/8 turn
5) Re-connect 2 pin socket connector – it will click in
Posted on Jan 07, 2009
steve_e_uk
  • 1675 Answers
SOURCE: How do I Replace headlamp bulb on 2006 C230 Benz?
hi here is a brakedown of the head light http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=211006&M=646.961&GA=722.699&GM=716.649&CT=F&cat=64U&SID=82&SGR=210&SGN=08
i gather you are having trouble with part 110?all you have to turn this in an anti clockwise direction, its a bit awkward to do but its doable, no special tools are required for this, just hand power...hope this helps
Posted on Feb 10, 2010
elstretchie
  • 140 Answers
SOURCE: Left turn signals won't flash, Right side works fine. Replaced front and rear turn bulbs (rear was burned out). Bulbs come on fine on the left side, they just won't flash.
Gday mate, we had a problem with another late model vehicle similar to that, the bulb that was put into the reverse light was not exact brand product ( ohmage was slightly wrong ) and fowled up computer, correct bulb in place and disconnect battery to reset K A M ( keep alive memory) problem solved, BEWARE, some vehicles cannot have KAM reset except for dealer computer tethered reboot , just try putting the factory correct bulb(s) in and see how it goes, geoff. hope this helped.
Posted on Feb 11, 2012
I have Sunquest Pro 16s tanning bed that I have just replaced all of the bulbs. One will still not light. Can anyone help?
There are no starters on the 16s. Did the position work before you replaced the bulb? If not and it still doesnt work with the new lamp, it is either a lampholder or ballast. If it worked before and doesnt now, it is either not in correctly or its a bad lamp, you can verify by swithching with another lamp
Jun 03, 2016 | Health & Beauty
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed
Check the bulb you adjusted, you probably got it in wrong, and shorted stuff out. Reset the bulb, and replace the fuses. At least you had fuses.
Nov 30, 2013 | Remington S 1007 Tourmaline Straightener...
2 tanning bulbsdont work. could it be the fuse in the bed
maybe they burnt out. you can use an UV reader, which lets you know when to replace the bulbs. it tells you how much UV light is being outputted. When you replace your tanning lamps, it is ideal to replace them all at once.
look here for more info http://www.mastertanning.com/tips/23/tanning-lamps/
Feb 26, 2013 | Health & Beauty
Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
Feb 18, 2013 | Health & Beauty
Just purchased bed. 5 lamps not lighting and 1 on canopy blew immediately after turning on. replaced lamps, replaced starters and holders. still have the same issue and have tried 2 more lamps in the one...
Have a trained technician to check the voltage going to the bed. If all bulbs / ballasts have same problem, this may be the problem. You may need a Buck/Booster.
Jul 04, 2011 | Wolff Sunvision Pro 24S Tanning Bed
Health & Beauty Logo
150 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
