Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
Not spining not working on spin will tumble dry and will wash
How do i tumble dry only on a lg hover wash machine
Washing machines don't have tumble dry. That would be a dryer. The best you can do with a washer is spin cycle.
Nov 08, 2014 | LG F1481TD5 1400 Spin 8kg Load Washing...
Hotpoint washer that is not spining clothes dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 01, 2011 | Hotpoint Washing Machines
Not spining properly on daily load cycle
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Mar 26, 2011 | Whirlpool Washing Machines
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | Washing Machines
I have a TB condensing tumble dryer, model TM310W, which has always worked well, but lately, although the clothes are drying, there doesn't seem to be much water going into the reservoir. I can't find it...
The first decision you must make when buying a tumble dryer is whether to buy a vented or a condenser dryer. As you'd expect, there are pros and cons for both. This page helps you understand all of the differences, including the reliability and repair implications. Condensor tumble dryers are becoming more popular but vented tumble dryers still have some advantages and the convenience of not needing a venting hose (as always) requires some compromises.
Until I can put together my own reviews the best Tumble Dryer reviews available online are by Which?
Due to their resources and independence, Which? usually have the latest reviews and collect the opinions and experiences of thousands of members - Which? tumble dryer reviews (Plenty of free information but will need to be a subscriber (take advantage of the 1 month trial offer to get the full benefit)
Vented tumble dryers are cheaper than condenser dryers, they are also simpler, more reliable and more economical to run. According to Which? "on average, vented tumble dryers use about a fifth less energy than condenser dryers to dry a full load of cottons."
So why bother with a condenser tumble dryer? Well condenser tumble dryers are a convenience product but they do offer a solution to a genuine problem for some where venting the dryer outside is difficult or even impossible.
My advice would be that if your tumble dryer can be sited somewhere that allows you to correctly vent it outside, either through a wall or through a window, then a vented dryer is probably best. If this would be particularly awkward, then buy a good quality condenser dryer, which should condense the steam into water.
Modern washing machines now have a far superior spin speed, and, of the ones we recommend, the cheaper model has a 1200 spin speed, the other a 1400 spin speed... so your washing will be fairly reasonable (some items could be about ready to iron) and this, in turn, could affect your other choices.
Could you get away with just airers and a washing line? Or have you considered a dehumidifier?
A Spin Dryer... will work efficiently, and is cheap. The main advantage to it is that it is only the size of a large pedal bin, so it can be stored under the worktop in a small amount of space.
A Tumble Dryer... much more expensive... for a decent quality item you need to pay a quite steep price. They do a good job, but are another full size kitchen appliance to find room for.
A Washer/Dryer... instead of a washing machine... disadvantages, if it goes wrong then you have no back up in either the washing or drying department... and of course being a more complicated piece of machinery, it IS more likely to break down! The only advantage is that it will be a space saving item.]
please comment on these on how helpful.
Dec 21, 2010 | Electrolux Dryers
My washer has been difficult to maintain balance when spin cycle is running for about a month. Also, the dryer has not been spining the clothes as dry as it usually did. Tonight, I put a load in and the...
You did not say what model washer you have. Top Load, Front Load and Model Number... That is very important.
As for the dryer..... If the washer is not getting a decent amount of water out of the clothes then the dryer could be becoming damaged continuing to use it. A dryer simply evaporates the water on tumbled clothes in it. It is is set on a TIME DRY setting, I doubt it will work at all. If it is set on AUTO DRY then, it could be running and running and destroying your dryer. You also may have a heating element that is weak or intermitently going on and off.
It is important to know how old, the brand, the model numbers of everything. Also if it is a Gas Dryer or Electric.
Sorry for the extra questions, but it is neccessary.
Kindly,
Jim
Dec 21, 2009 | Maytag Washing Machines
Maytag mhw2000aww neptune front load will not spin dry ,door does not lock will go through entire wash with out spining dry
The timer is likely failed on this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Maytag Washing Machines
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
22 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
