Question about Roku Televison & Video
Can roku be used with a cable box or do I just have to use one or the other?
I just bought it and I have a couple of TV's with cable boxes and a couple with out that is just on basic cable. Do I need to disconnect the cable 1st?
  • Roku Expert
  • 138 Answers
If you have another HDMI port or A/V cable available on your TV, you don't have to unplug the cable box from the TV. You'll only need to connect the Roku to the vacant Input ports (HDMI or A/V) and change the input source of the TV accordingly.
Posted on Feb 11, 2014
2 Suggested Answers
randyprevost
  • 887 Answers
SOURCE: new router now roku box does not work
Are other devices able to connect? If not, then you're probably entering an incorrect password or you're trying to connect to the wrong network.
Hope this helps
Randy
Posted on Oct 10, 2012
Pros And Cons Of Roku
Roku is one of the best streaming devices to stream the videos, movies and TV shows.
Pros of Roku
The Roku offers user interface and Roku app in cheaper packages.
Roku does not require the separate box or HDMI cables to connect the TV from the stick plugs.
It has screen mirroring features that display the screens of the mobile device on you Roku tv.
It has the search function to search the lists of channels from the channel stores.
It provides headphone jack for private listening.
Cons of Roku
For the Network connection, Wifi is the only option
You need HDMI cable for Roku stick because it lacks analog and digital audio outputs.
If you need further more information about the roku products contact the roku customer service team @ +1-844-965-4357 and you may visit https://www.rokuactivationcode.com/
Apr 06, 2017 | Internet Computers & Internet
On my LT42HVi with HDMI input source, the image comes through with a lot of green then will change back to normal color. Switching cables or HDMI input port makes no difference. Using normal TV inpu
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
Jan 02, 2015 | Olevia LT42HVi 42 in. LCD Television
How to connect Roku 3 or do I need Roku 2?
I think it will only work if connected directly to the tv with the correct cable.
Dec 27, 2014 | Pioneer Televison & Video
How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
Dec 25, 2014 | Roku 2 HD
How do i connect many devices (sky box X 2, bt box, etc) to 4 tvs in public house
You will only be allowed to watch 1 channel at a time if you have one box and use coax cable. If you have WI-FI using a sling box and roku (apple TV) adapters you can change the channel at each location but you still will only be able to watch one channel but you could watch the channels available on Roku. Best solution,and also the most expensive , is to have a cable box at each loaction.
Oct 17, 2014 | Televison & Video
How do i hook up roku player to tv that has cable tv box
Use an hdmi cable from the roku to an available hdmi on the backside then using your tv remote find the source channel on your tv follow the promts from roku.
Apr 26, 2014 | Roku HD Player (N1100)
I only have on set of white, yellow & red receptors on back of tv. There is a set (entitled Video 2) on the side of the tv.1st - can I attach the Roku to the receptors at the side of the tv or2nd - i...
You didn't say which Roku you have, so I will assume you have a Roku 3 since it's the only one without RCA output jacks (the red, white, and yellow jacks you mention). You can return the Roku 3 and get a Roku 2. You can only attach the Roku to a switching box if 1) the Roku has the RCA outputs and your switch has A/V inputs. If you DO have the Roku 3, then you may be able to purchase a HDMI to RCA cable from Amazon http://www.amazon.com/HDMI-RCA-VGA-Cable-1-8m/dp/B002ZUI68G
Mar 03, 2014 | Televison & Video
Using Roku 3 with HDMI cable to stream to TV, is there a way to get an audio out signal (either from the TV or Roku box) to connect to an analog stereo receiver
Your tv should have a couple different audio out options, but you can not just plug in a wire and make it work. You will have to use your remote to go into your settings on the tv and select an external speaker before it will actually send the signals out.
Oct 11, 2013 | Televison & Video
WE JUST BOUGHT ROKU , HOOKED IT UP , CAN'T GET ANYTHING ELSE TO COME UP
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
74 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
